Somthing wrong w 4.10 gears? - Page 2 - MustangForums.com
Old 05-23-2012, 10:34 AM   #11
mustang99v6
mustang99v6's Avatar
Boy, this thread went downhill fast! Dr. Le listen, 4.10's aren't like some magical turbo boost. So maybe your idea based off what "others" are telling you just isn't lived up to, but that doesn't mean the work wasn't done. Instead of assuming the worst, start verifying things. Did the shop give you your old gears back? If not, go get them. Double check your new parts order slip and make sure of what you ordered. If neither of those answers your question, then pony up the money for a new gasket, sealer, gear oil, & additive. Then just crack the pumpkin open and count your gears.
mustang99v6 is offline   Reply With Quote
Old 05-29-2012, 01:24 PM   #12
Dr.Le
Dr.Le's Avatar
Quote:
Originally Posted by mustangman02232 View Post
did you get them for the 7,5 or 8.8? whats your rpms at XX mph?
I got the 7.5
before the gears its 2300@75mph now its 2600@70 ... sorry i didnt take it to 75mph (break in period).
but that feels high.
im in an auto and my tires are 245/45/17.
Dr.Le is offline   Reply With Quote
Old 05-29-2012, 01:26 PM   #13
Dr.Le
Dr.Le's Avatar
Quote:
Originally Posted by jthorn9 View Post
Reputable or not, the installer screwed you. That or you got the wrong parts.
FYI, shops HATE installing parts you bring in. As a result they will be more inclined to screw around or mess up the install cause they don't have to warranty the parts and they make no extra dollars off comission for the parts.
Yeah, i got the feeling when i told them ill be bring in the parts and i want the labor cost only. they didnt like it too much.
but i was saving 100+ buying parts online instead of from them you know.
Old 05-29-2012, 01:29 PM   #14
Dr.Le
Dr.Le's Avatar
Quote:
Originally Posted by johno2b View Post
if its a matter of feel, going from 3:5/3:7 to 4:10's, not much feel. That will need to be taken into account. Tire height also comes into play. Taller the tire, less the feel.
so after, i search for post similar to this
"disappointing w/ 4.10 gears swap"
and yes i did find a few of them and my face went green after.
Old 05-29-2012, 01:32 PM   #15
Dr.Le
Dr.Le's Avatar
Quote:
Originally Posted by 03shadow View Post
that too. i could see a shop replacing stock gears just to make it seem like they did some kind of work.
next time you get work done, request to keep your stock parts. dont let them have them because 1) you may decide put the stock parts back in, and 2) requesting to keep them will make the shop a little more likely to actually do the work, the stock parts can be proof for them and assurance for you
man, i did not ask for parts back. i've always done installs and mods myself. not much experience w/ mechanics.
now i know what to do for next time around.
Old 05-29-2012, 01:34 PM   #16
Dr.Le
Dr.Le's Avatar
That's my thinking too, that they kept the 4.10s and just "tinkered" with the rear end.
Best way to tell...jack your car up in the rear (both sides) make a mark on the drive shaft (marker, white out, or a rock) and count the revs the drive shaft makes per 1 tire rotation. If you count anything less than 4.10 rotations per wheel rotation, they screwed you and you need to go back there and unload on them.
i think thats what happened to me, cuz when i came to pick up the car, we didnt even test drive it... it was 8:30pm btw so i wanted to get out of there too.
Old 05-29-2012, 01:41 PM   #17
Dr.Le
Dr.Le's Avatar
Okay i got the answer to all these questions and inquires.
here's what happened.. from the beginning.
I called the shop asap and told them about the situation, saying that i didnt see/feel much performance gain, MAYBE there was something wrong. I asked if they can test drive it for me to see if everything was okay.
the response: you'll have to bring it in on a sat b/c our "gear" guy only work sat and he can if you a better and more accurate answer.
so i waited a whole week, labor day weekend came, i called and the shop said its really busy today and asked if I can drop the car off at the shop and the gear guy can get to it ASAP.
so that's what i did.
Old 05-29-2012, 01:51 PM   #18
Dr.Le
Dr.Le's Avatar
Later, i picked it up and the drive was a beast!!! YES it pulled and NOW I understand the 4.10 smile i was waiting for.
Here's the mechanic explanation...
you had a pcv failure and that caused HP lose
and we did NOT load your tunes in the FIRST time around. We didnt know if you had a custom tune or not.
what we did was used the sct and changed your gear/tire ratio to match the speedo.
So what do you guys think? is this plausible? sounds convincing too huh?
well before, i was running 91 bama tune only and i added +2 on the timing w/o any knock.
so maybe i got used to the "power of 91 octane" tune and the integrative strength of my other bolt on mods that a NON-tune off set my 4.10 gears?
thats the logic or explanation but who knows..... im happy w/ the gears now. and i've learned a lot when working w/ mechanics.
thanks for all the inputs. i hope my situation add on and helps out the next person.
Old 05-30-2012, 03:13 PM   #19
robb15033
robb15033's Avatar
A little bit confusing because it's pretty normal to receive dyno sheets with the custom tunes they should have provided you after the dyno tuned it.
After the work they did, it should have been done that way, in my opinion
robb15033 is offline   Reply With Quote
Snow performance stage 2 MAF boos cooler install jwog666 Pipes, Boost & Juice 5 04-04-2016 05:23 PM
Possible Clutch Issues..? Thunderball 4.6L (1996-2004 Modular) Mustang 15 11-23-2015 12:49 AM
Starting a new project....could use some input. Matt's 95 Stang 5.0L (1979-1995) Mustang 2 10-05-2015 08:16 AM
So who wins uedlose The Racers Bench 4 10-01-2015 09:31 PM
Centerforce Clutch, will a exedy flywheel work? junior04 4.6L (1996-2004 Modular) Mustang 1 09-28-2015 11:53 AM
2003, 410, 46l, 65, 95, auto, black, cobra, end, gears, mustang, rear, show, size, svt, tires
