Anyone running SYLVANIA SilverStar's?
We have a 2002 Mustang convertible V6/ Auto also and the headlamps are dim and yellow. I found smoked replacement headlamp assemblies $104.00 for the pair from 1A auto.com but no new bulbs. anyway I wanted to upgrade the headlamps and was thinking of getting the SYLVANIA SilverStar ULTRA High Performance Headlights to go with the new assemblies.
Question I have are they that much better than OEM lights.
Worth the money?
Worth the money?
I do not believe they are any better then OEM. I bought them for the same purpose (to see better at night, ect) but I did not notice one little bit of diffrence over the stock ones. If you want brighter go with HIDs.
Matthew
Matthew
I had the same kind of bulb as well, I noticed a SLIGHT difference in brightness, it was also a litte whiter than the OEM bulbs. As Matt said, if you want bright, go HID. I've had multiple pairs on all my cars, blue, white, yellowish white, and I liked them all (blue made the most people flash their high beams at me)
Also I wouldn't buy something off of Ebay, I bought 3 pairs before I went to a shop that sold them for $60 and a 9 month garuntee.
Josh
Josh
IF you're going to get smoked housings and you've never had them before... don't waste your time with Sylvania silverstar. Speaking from experience, waste of money... I went through like 4 pairs like ~180$ in total and I couldn't see anything until I got HIDs...
Remember, by smoking the housing, you prevent light from passing through....in as well as out.
Worth the money?
Worth the money?
I have HID's now but, the Sylvania Silverstar zXe is the very best, brightest, whitest halogen bulb I ever used. The zXe set is way better than the other two Silverstar versions they make. If someone happens to be in Northern Va. I have a slightly used set to give away.
I will never buy a HID kit unless I did a projector retrofit project.
Like I said, the zXe Silverstar bulbs are fantastic but I will never go back to halogens now that I've used my HID's. It's a matter of life safety. I have them accurately adjusted a slight bit low to limit any glare. These "Black Beauty" headlights did not function safely with halogens-
This Is Sylvania Silverstar zXe Halogen Bulbs:
I have used all they have had to offer right up to the $50+ dollar Ultrastar's and they are no match for HID's.
Another thing to remember is that the higher the performance of those bulbs, the shorter the life of them. The Ultra's average a 12-24 month life. Do you really want to be spending $50+ dollars ever 1-2 years?
Lets not forget as they age they dim, so 1/2 - 3/4 of the way through the life they are just as dim as the stock ones.
A quality HID high/low beam kit is what you will want to look for.
