bad vibration, misfiring - Page 2 - MustangForums.com
Old 12-01-2012, 08:53 PM   #11
jthorn9
The Godfather
jthorn9's Avatar
YOU NEED TO REPLACE THE GASKETS WHEN YOU PULL THE INTAKE!!!!!!!! Now the problem is being made worse by a vacuum and water jacket failure with the gasket.
jthorn9 is offline   Reply With Quote
Old 12-02-2012, 08:18 AM   #12
snooky012002
Working on that right now hopefully have it done in couple hours
snooky012002 is offline   Reply With Quote
Old 12-03-2012, 12:43 AM   #13
snooky012002
changed the gasket no more water in oil, 3rd bank on coil sometimes has no fire from it and when it does t doesnt change the way motor runs when u pull wires, so im guessing coil is bad and what would make it not change motor when pulled off????
Old 12-03-2012, 04:58 PM   #14
jthorn9
The Godfather
jthorn9's Avatar
Yep, that's the symptoms of either a bad coil, or a random stroke of all bad wires.
Old 12-04-2012, 08:00 AM   #15
RyansQuick6
Reverse Gear Member
RyansQuick6's Avatar
If you replaced the coil what brand did you go with? Motorcraft coils are the only ones that work properly. Also with the plugs, if you put in platinums, that can be a problem too as platinums suck. Just get some NGK TR-5's. If you have a broken spark plug, then you probably have either piston or valve damage, or both. I'd recommend pulling the head/s just to make sure. It sucks to have to do it, and it'd not cheap for all the bolts and gaskets, but at this point it's the only way to be sure. I've seen heads eaten to **** from a spark plug breaking.
I highly doubt it's a timing chain issue, merely because those of us who have put our cars through the most abuse have yet to have an issue. If it breaks it breaks, and the car won't run.
RyansQuick6 is offline   Reply With Quote
Old 12-05-2012, 05:55 PM   #16
snooky012002
i know the harmonic balancer needs changedd so thats the next thing im doing sometime soon
Old 12-05-2012, 08:35 PM   #17
RyansQuick6
Reverse Gear Member
Um, do that asap. That will destroy your engine. The whole point is to BALANCE out everything. It's worse than driving with a tire out of balance.
S197 Parts baddog671 Parts For Sale 20 07-26-2016 02:20 PM
Bad cylinder? Dathan V6 (1994-2004) Mustangs 4 10-05-2015 06:52 AM
What other parts should I be concerned about if my pinion bearing went bad? KingRando 2005-2014 Mustangs 5 10-02-2015 09:06 AM
I should've known better ChampInSD 5.0L GT S550 Tech 13 10-02-2015 05:55 AM
Rough idle and vibrating 4cylinderplus2 V6 (1994-2004) Mustangs 9 09-30-2015 06:26 PM
misfire, rough idle, shaking, vibrating
