Compatibility Question
Old 01-23-2013, 10:57 PM
  #31
1slow67
ROTM Moderator
1slow67's Avatar
Originally Posted by jthorn9
94/95 V6s did not come with the strut tower brace, that was taken off of a 94/95 5.0. That's the way its made, it will fit 94-04 Mustangs, however there may be clearance issues that will require custom bending to make it fit or you have to get an aftermarket one. For example, the sway bar won't even fit 94/95 5.0s that have aftermarket upper/lower intakes, or intake spacers.
I've tried installing that exact strut brace on my 03 and it did not fit. It was too short, the back was a good inch away from the firewall.
1slow67 is offline
Old 01-24-2013, 12:15 AM
  #32
Mrizk1
Mrizk1's Avatar
Really? It fit perfectly on mine
Mrizk1 is offline
Old 01-24-2013, 10:30 AM
  #33
1slow67
ROTM Moderator
1slow67's Avatar
Yeah it wouldn't fit. Yet I took it off of a SN95 car, didn't make sense.
1slow67 is offline
Old 01-24-2013, 09:13 PM
  #34
Double0SixShooter
Double0SixShooter's Avatar
Personally, in regards to the PaceSetter comments, I like the sound difference they make, however they ARE EXTREMELY difficult to install.. I've done them twice, on 2 friends cars, the problem is that you would need to remove the upper intake, and valve covers to increase clearance however they still drive into the firewall on the way down and come over the heads quite a bit, in other words, they get stuck. We spent hours trying to get them on in both scenarios. Eventually we got them by reshaping some things, and I like the sound difference, but idk, the amount of work you have to put into them is immense. Although I must add, one of my friends says he notices better top end performance.
Double0SixShooter is offline
Old 01-25-2013, 01:36 AM
  #35
Mrizk1
Mrizk1's Avatar
That sounds like a lot of work, I think I'm gonna skip out on those haha
Mrizk1 is offline
Old 01-26-2013, 01:43 PM
  #36
Double0SixShooter
It was for us, but I'm sure someone has been able to get them in well. Hopefully they will comment. I'm sure the other brands are different. But that's just my experience with them lol.
Old 02-10-2013, 02:29 AM
  #37
Mrizk1
Mrizk1's Avatar
Hey guys, its been a while! Well the local junkyard is having a 50% off sale and I wanted to pick up a t lock for my car, or just switching out the rear end entirely. The 8.8 rear end has a lsd in it already right?
Thanks!
Mrizk1 is offline
Old 02-10-2013, 02:41 AM
  #38
Mrizk1
Mrizk1's Avatar
Oh and also I already started on a 84 gt with the 7.5 rear end but I didn't have the proper tools to completely disassemble it. How do I remove the the axles so I could pull out the diff?
Mrizk1 is offline
Old 02-10-2013, 08:03 PM
  #39
jthorn9
The Godfather
jthorn9's Avatar
I've seen that before on some 99-04 Mustangs they'll fit, some they won't. Basically some car the metal flange at the back of the engine bay is the right size and on some its either shorter or non existent, just depends.
jthorn9 is offline
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
junior04
09-28-2015 10:53 AM
Quick Reply: Compatibility Question
