Harmonic Balancer install problems
Old 01-31-2013, 12:21 AM
petrock
petrock's Avatar
Default Harmonic Balancer install problems
I’m trying to install the harmonic balancer on my wifey’s ride (’98 3.8L). I rented an installer tool from AutoZone that I’ve used before on other vehicles, but it won’t work on my wifey’s car due to the balancer’s design. The bore where the tool goes is too deep, so the large nut on the installer tool is effectively inside the bore making it impossible to get a wrench on it in order to turn the nut.
What am I missing? How does everyone else install the stock harmonic balancer on their 3.8L motors? Is there a different tool I should be using? One specific to mustangs or something? Or am I just “doing it wrong”?
Thanks in advance...
petrock is offline
Old 02-02-2013, 03:51 PM
petrock
petrock's Avatar
Bump bump...
petrock is offline
Old 02-20-2013, 11:52 PM
petrock
petrock's Avatar
Anyone?
One idea I got was to rent a second Harmonic Balancer installer and take roller bearing in that kit and stack it with the roller bearing from the first installer kit in order to position the nut further out in order to get a wrench on it. This may work, but I'm not sure if it will bind or not. My local autozone doesn't have any more installer kits. They are all being rented at the moment. Who knows when they will get one in. I'm getting ready to put the motor back in the car, so I need to figure this out soon.
petrock is offline
Old 02-21-2013, 10:54 PM
stangant
stangant's Avatar
I think when I did it I took the washer off and used that with the installer.
stangant is offline
Old 02-22-2013, 07:13 AM
Stevo86
Stevo86's Avatar
Tap it on first with a soft faced hammer. Get it on far enough that the bolt and washer will grab a few threads. Than snug it down with the bolt and washer. You only need the tool to take it off. Once you're spinning the engine and not the bolt, you've got it in there.
Stevo86 is offline
djbigskrilla
09-20-2022 01:04 AM
JonnyBlazeGT
11-03-2015 01:10 AM
1987gt40ttopt
08-28-2015 10:49 PM
Urambo Tauro
08-27-2015 10:53 AM
jjwinel78
08-17-2015 03:34 PM
Quick Reply: Harmonic Balancer install problems
