Break lights, binkers, and shifter is not working in my 95 3.8 V6
The other day i went to get into my car, 95 V6 Automatic mustang base model, and the shifter would not come out of park. Later my blinkers are were not working, then i found my break lights were not working. HELP I DO NOT KNOW WHAT IT IS?
to me that screams security system...seems to have locked you out. But thats just my guess. Each symptom can have it's own cause but for all 3 at once it says security system to me.
Any evidence of someone trying to steal your ride like the ignition tampered with?
hopefully it is just a simple fix....there is a sensor under the drivers side dash, should be on the brake pedal/lever. make sure its connected for one and that the wiring is in good condition. That sensor is the brake light/trans lock out in one unit... i bet its that...
Theft light flashing? PATS system can go into the toilet for a wide variety of reasons, not just an obvious failed break in. Mine went due to a faulty wiring harness on this car. And my last cars PATS went south due to a failing CCRM.
Diode Dynamics
28
05-26-2022 12:02 PM
inyadreems
08-21-2015 09:10 AM
