Replaced Camshaft Sensor, now running slower?
Old 05-15-2013, 08:23 PM
3.8Cobra
3.8Cobra's Avatar
Default Replaced Camshaft Sensor, now running slower?
So, that evil Check Engine light came on in the 95 V6. When I had it tested, it said that my Camshaft sensor was shot. Witch would explain why when I drove at low RPMs, the engine would skip a beat. Either way. Now that I had it replaced and reset the computer, it seems like my car doesn't have the get-up-and-go like it used to. Any idea why or what I did wrong?
Thanks.
3.8Cobra is offline
Old 05-16-2013, 08:08 AM
musicbox
musicbox's Avatar
Did you just get this information from a OBDII? Like from an Auto Parts store or did you go to a shop?
musicbox is offline
Old 05-16-2013, 09:46 AM
3.8Cobra
3.8Cobra's Avatar
Got the part and the scan from Autozone and replaced it myself.
3.8Cobra is offline
Old 05-17-2013, 07:08 AM
musicbox
musicbox's Avatar
See, the thing with those OBDII code readers, (especially the ones that us part stores use), aren't a complete diagnostic reader. It basically just pulls codes and even then it may not be exactly what is wrong with it, it just gives you a general area of where to start. I assume they didn't tell you that at AutoZone?
musicbox is offline
Old 05-19-2013, 10:17 AM
3.8Cobra
3.8Cobra's Avatar
No, they didn't.
3.8Cobra is offline
Old 05-29-2013, 09:34 AM
musicbox
musicbox's Avatar
You need to go have a shop or mechanic actually run a diagnostic on it. The little OBDII's we use at the part stores just pull codes, they don't actually diagnose, and a lot of the time, just because a camshaft code came up, doesn't actually mean it's the camshaft.
I know it's been a little while since I was in here, did you get the problem resolved?
musicbox is offline
Old 05-30-2013, 04:13 PM
3.8Cobra
3.8Cobra's Avatar
Yeah, it's all good now. TPS also went bad, but I just got it resolved yesterday. I just happened to be lucky and bought a defective sensor. Thanks though.
3.8Cobra is offline
djbigskrilla
09-20-2022 01:04 AM
bryan616fl
01-25-2019 09:07 PM
mirandaandjimmy
11-16-2015 08:51 AM
timeformiller44
08-26-2015 12:03 PM
mweiland
08-16-2015 10:59 AM
Quick Reply: Replaced Camshaft Sensor, now running slower?
