3.73 gear swap - any FYI's to know about?
Old 05-22-2013, 06:00 PM
Toadster
Toadster's Avatar
Lightbulb 3.73 gear swap - any FYI's to know about?
considering our 'stang has ~146k miles on it and the rear diff will most likely go in the next 5k miles - we're considering a bump to the posi diff and 3.73 gears
obviously there's the cost in getting this done and a local shop will do the swap from open to posi plus gears for ~$900
what caveats should we look out for? any oil recommendations? also what about daily wear/tear?
the shorter gears will reduce highway mileage, but around town I'd expect the same or maybe better?
Toadster is offline
Old 05-22-2013, 11:01 PM
Toadster
Toadster's Avatar
nobody?
Toadster is offline
Old 05-26-2013, 10:06 PM
302_Mustang
302_Mustang's Avatar
If I were you I would do a rear swap from a GT. I had 99 V6 and got a rear from 99 GT with 67K for $100. The GT rears come with a factory Limited slip. They are also stronger than the factory 7.5 that came in the V6. It would also be cheaper than buying a Posi rear for a 7.5, the last time I checked they were around $450 not including installion. If you do decide to do a rear swap it is VERY easy. All you got to do is drop your old rear and bolt up your new one, everything lines up with no modification. Lets say you pick up a rear off a GT for around $150 and the gears for $160 plus installation $300 it would be almost half of you estimated cost.
302_Mustang is offline
Old 05-28-2013, 05:39 PM
Toadster
Toadster's Avatar
yes, but GT's didn't come with 3.73 did they?
plus that adds like 80lbs too
Toadster is offline
Old 05-28-2013, 05:53 PM
BabyGT
BabyGT's Avatar
The gear swap will more than make up for the extra weight. You can get a gt rear for much cheaper than a limited slip for a 7.5 then you only have to buy gears and have them installed. You will save a few hundred and have a much better rear end.
BabyGT is offline
Old 06-01-2013, 03:06 PM
Toadster
Toadster's Avatar
man those 8.8" rears are hard to find around here... Sacramento area
Toadster is offline
Old 06-01-2013, 08:49 PM
jthorn9
The Godfather
jthorn9's Avatar
Ebay is your friend for those 8.8" rears.
jthorn9 is offline
Old 06-01-2013, 08:59 PM
302_Mustang
Junkyards or Craigslist auto parts
Old 06-02-2013, 01:05 AM
Toadster
Toadster's Avatar
cheapest ones I'm seeing are about $500 without shipping, then I'd have to do gears and installation
a local gear shop can do tlok with gears for about $700 all new
Toadster is offline
Old 06-02-2013, 07:51 PM
jthorn9
The Godfather
jthorn9's Avatar
Tlock in a 7.5" rear for $700 = money up in smoke = paperweight
jthorn9 is offline
Quick Reply: 3.73 gear swap - any FYI's to know about?
