99 Convertible top out of adjustment - MustangForums.com
Old 06-19-2013, 05:05 PM   #1
MDSoxFan
Default 99 Convertible top out of adjustment
1999 convertible had a bad emergency parking brake switch which caused the convertible top to get stuck in the down position. Due to approaching storms, my daughter and her friends were able to close the top . I replaced the switch and now the top closes but is 5 inches from the windshield. When you pull the top frame to lock it in, a buckle develops on the drivers and passengers side frame. It doesn't appear that they bent anything but something is definitely out of whack. The windows don't come close to sealing. Any ideas?
MDSoxFan is offline   Reply With Quote
Old 06-20-2013, 02:53 AM   #2
petrock
Clearly something is out of alignment and/or bent. It is hard to say what it is without having the car in front of me. Id start poking around looking for what is binding when you try to close it. Failing that, take it to a convertible shop to take a look at. Good luck...
petrock is offline   Reply With Quote
mysterious water leak zsmart Convertible Tech 2 02-29-2016 08:33 AM
Two 1966 Convertibles to restore GPR Classic Mustangs (Tech) 12 12-16-2015 12:21 PM
1965 Straight 6 Automatic Transmission Torque Converter Issue LivingInThePast Classic Mustangs (Tech) 2 09-16-2015 12:20 PM
E brake adjust help DoctorScary General Tech 6 09-09-2015 07:53 AM
