Gauge Sweep and warning lamps flash while Driving
Old 07-05-2013, 09:19 PM
GoldMustangV6
GoldMustangV6's Avatar
Default Gauge Sweep and warning lamps flash while Driving
Ok so I have an 02 3.8 v6 with this problem. It started a couple days after i installed a new amp and sub in the car. There was existing wires ran already for a system that was previously installed. Everything was working great for a day or so. Then while driving down the road my gauges sweep and all of the warning lights in the dash flash. The headlights also turn off and the car feels like it is being jerked. I am stumped on this, i have looked all over and found no info. Please help Me this is annoying as H***!
GoldMustangV6 is offline
Old 07-05-2013, 11:47 PM
Daehawk
Daehawk's Avatar
Loose connection somewhere. Id start with the battery cables and car ground.
Daehawk is offline
Old 07-06-2013, 12:04 AM
BabyGT
BabyGT's Avatar
Yep, or the amp you installed is drawing more power than the alt can produce during particularly hard hitting bass notes.
BabyGT is offline
Old 07-06-2013, 12:35 AM
GoldMustangV6
Thanks for the suggestions guys. I checked the battery terminals and they seemed tight although they are pretty corroded. As for the ground, is that connected to the fire wall? And where could I find it. I'm a complete beginner on most vehicle knowledge. The amp that was on before used a 30a fuse, the one I have now uses a 50a fuse, would that make a difference? Thanks again
Galactic
04-29-2019 02:56 PM
Nick Oliver
10-17-2018 04:22 AM
StalkerGT
09-25-2015 02:41 PM
Pyrate Dave
09-10-2015 07:30 PM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: Gauge Sweep and warning lamps flash while Driving
