not receiving enough gas when first start, causes it to almost stall and very low acc
Old 09-28-2013, 09:30 PM
tspina94
tspina94's Avatar
Question not receiving enough gas when first start, causes it to almost stall and very low acc
i have a 1998 v6 mustang 5speed with a single mod (intake) all els stock.
when i first start up car it doesnt receive enough gas that i give it and it causes it to buck and shake almost to the point of stalling at first gear, after 10-15 mins of driving its fine and it respawns normally.
i have no idea whats wrong with it, its almost like it take really long to warm up but to the point of stalling is extreme and not normal . need help please !!!
tspina94 is offline
Old 09-29-2013, 12:29 AM
Maverick710
Maverick710's Avatar
Ok do you have a check engine light on?
Maverick710 is offline
Old 09-29-2013, 09:04 AM
tspina94
tspina94's Avatar
No I don't, no dummy lights or anything. It has about 113,000 on it. When I first start my car though the temperature stays on cold for like 15 mins then makes its way to normal in the middle slowly, I don't know if that's just normal though.
tspina94 is offline
Old 09-29-2013, 11:51 AM
Daehawk
Daehawk's Avatar
Kinda normal. Mine takes about 5 min to start moving. Maybe a little longer.
Daehawk is offline
Old 09-29-2013, 04:25 PM
tspina94
tspina94's Avatar
Well I understand the car needs to warm up but 15 mins is long, and I live in FL so it's already not cold here haha, I don't know if there's anyway to improve this, maybe new spark plugs or mass air flow or something.
tspina94 is offline
Old 09-30-2013, 12:45 AM
Maverick710
Another question is, how long has it been since youve changed the fuel filter? And if hasn't been to long how much pressure are u getting from the fuel pump?
Old 09-30-2013, 02:20 AM
petrock
petrock's Avatar
Unless its over 100 degrees on a daily basis, it will still take some time for the car to warm up. Warmed up is the motor temp at around 180-190 degrees (depending on your thermostat).
I would also test your IAC valve (idle air control valve). Search the forum there are a lot of post with similar symptoms. Good luck..
petrock is offline
Old 09-30-2013, 02:08 PM
tspina94
tspina94's Avatar
That I don't know, I never asked the previous owner of the car, but I'm willing to change it always.
And okay thank you, I'll look into testing it, appreciate the feed back.
tspina94 is offline
Old 09-30-2013, 11:50 PM
MaxOrbit
MaxOrbit's Avatar
Going out on a limb here but I'd suspect a faulty coolant temp sensor. It should tell the ECU that your motor is cold and enrich the mixture like an old time choke. I have no idea where this sensor is located.
MaxOrbit is offline
Old 10-01-2013, 02:46 PM
tspina94
tspina94's Avatar
Okay that's sounds what it can likely be acutely, I think I may have a idea but I'll research to find it, thanks!
tspina94 is offline
Quick Reply: not receiving enough gas when first start, causes it to almost stall and very low acc
