Mustang Front end Noise **Video**
Getting disgusted with this mustang already my 2000 was twice the driving car this 02 was. guess its how they were all taken care of.. this noise appeared after i went over a speed bump any suggetions will be greatly apprechiated.. checked all lug nuts there all tight checked wheel play its seems tight feels like its coming from driver side front.
Other problems that it could be are a bad tire with a broken belt, or bulge.
I would expect it to be present in the steering wheel all the time if it was a tire.
Bad wheel bearing . Likely wouldn't feel it in the steering wheel , but could feel it through the car.
It does sound like a warped rotor, but hitting a bump shouldn't have effected it. I guess I would start basic and check tires first. Rotate tires front to back if possible and see if the noise changes where its coming from. When you have the front tires off then you can roll them and see if there's a bulging spot where a belt may have let go, or if there's goose eggs on the sidewalls on the inside.
Definitely inspect the tires. You may have run over something and it got stuck in the tread. If so, it could cause a puncture/blow out over time. So look into it quickly. Rotating the tires front to back is also a good idea to see if the noise changes. If it does then you know its the tires.
It could also be that some other component gave way and is hitting something in the engine bay. Like a bad pulley bearing, harmonic balancer or serp belt. Good luck...
You may be on to something, A stone stuck in the tread +1
found out what the problem was my wheel spacers loosened off , tighten em up n no more noise , i got an other question for you guys.. my power steering pump is really loud and its gone in my opinion but if i have my wheel all the way turned u can see my motor losing rpms etc its like its drawin power from my motor would my pump do this ?
In others words… thats normal. :-)
My pump is really noisy though and its whining like a bugger , would a video help any? i just dont like when i put the car in neutrual or turn my wheel or press my window to go up or down my rpms fluxerate also. it never stalled on me yet but it goes down towards like 400-500 rpms brand new battery in the car..
