Last edit by: IB Advertising
Browse all: Steering & Suspension Guides
- Ford Mustang Gt 1996 to 2004: How to Install Rear Lower Control Arms
Step by step instructions for do-it-yourself repairs
LOWER CONTROL ARM BUSHINGS (REAR AXLE BUSHINGS)
No problem.
My wifey’s mustang is also a daily driver. By no means a performance car. I wouldn’t call polyurethane bushings something for performance though. To me they are a maintenance item given the stock bushings age. I did it mainly to keep the wheels tracking straight so they don’t wear unevenly/prematurely. Good tires are expensive. So it makes financial sense to replace your stock bushings if they are worn out.
Yeah, you might be able to get by with pick-n-pull bushings off wrecked cars for a while but those bushings will be just as old as yours are. They may look good when not under load, but once you bolt them on and put the weight of the car on them you start to see all the cracks/distortion etc. Its the nature of rubber to degrade over time. No way to avoid it. Just sayin’…
btw, not for nothin’, but the Energy Suspension bushings I listed above are $78 from summitracing.com. To replace all 8 rear control arm bushings, that works out to be about $9.75/bushing. You can probably find them cheaper elsewhere. Just sayin’...
No problem.
11-10-2015 11:39 AM
musnicki
09-23-2015 07:11 AM
Dragonus18
09-09-2015 01:21 AM
09-03-2015 07:14 PM
