White Face Gauges
03-04-2014, 01:20 PM
White Face Gauges
Recently bought a set of white face gauges for my 02 V6. Has any one ever messed with one of these? Are there any tips you got on an easy way to install them? The kit has the small black power inverter and an on/off switch and a dimmer dial. Thanks in advance for any help.
03-05-2014, 10:51 PM
Turn the key on and remember where the gas gage is. You will need to put the needle exactly back in the same place with the key in the on position.
03-07-2014, 02:02 AM
Actually start it and let it run 30 min and mark all needles. Any of them off and you are messed up. then on new install start 30 min and replace needles same place they were. gauges can be a mess.
03-13-2014, 08:57 AM
and if you do mess up you can always run your your cluster in test mode to see how off you are but that will only get you so close. took me several hours to get mine excat again.
jwog666
12-27-2021 08:09 PM
b8checker
10-08-2015 12:55 PM
breaking
10-02-2015 01:27 PM
14gt_Track
10-01-2015 02:47 PM
MacSerio
09-27-2015 01:05 PM
