01-98 swap need help! - MustangForums.com
Old 03-30-2014, 06:54 PM   #1
mwc0404
mwc0404's Avatar
Default 01-98 swap need help!
I have a 98 3.8 v6 with a blown engine and a complete 01 engine minus wiring harness. What i need to know is if i can put the 01 engine into the 98 and if so what kind of things specifically will be problematic. Just from looking at it for a minute it appears the fuel rails are different and the 01 only has one fuel line whereas the 98 has 2 fuel lines that run to the rail. Any advise or if anyone has done this swap info would be greatly appreciated!
mwc0404 is offline   Reply With Quote
Old 03-30-2014, 07:07 PM   #2
LilRoush
LilRoush's Avatar
You'll need to address the fuel system (return in your car vs returnless on the newer motor).
You can get everything you need from Super Six Motorsports.
LilRoush is offline   Reply With Quote
Old 03-30-2014, 07:40 PM   #3
mwc0404
mwc0404's Avatar
so from what your saying it sounds to me like your saying there is a kit of some sort that converts 2 fuel lines into 1 fuel line. Is that correct?
Old 03-31-2014, 09:59 AM   #4
mwc0404
mwc0404's Avatar
So from what ive figured out it seems a 96-98 windstar fuel rail will fit an 01 motor and has the return system also. Anyone know if this is correct or have any experience with that?
Old 04-01-2014, 08:09 AM   #5
BabyGT
BabyGT's Avatar
You don't need the return for the new motor.
BabyGT is offline   Reply With Quote
Terminated Whipple GT battles '13 GT500 on E85 Bokeo Street/Strip 6 10-10-2015 09:28 PM
Starting a new project....could use some input. Matt's 95 Stang 5.0L (1979-1995) Mustang 2 10-05-2015 08:16 AM
4 Valve Head questions GimpyHSHS 4.6L (1996-2004 Modular) Mustang 6 10-01-2015 10:01 AM
4r70w torque converter q's guitarman376 4.6L (1996-2004 Modular) Mustang 0 09-30-2015 06:54 PM
GT500 front LCA question UrS4 S197 Handling Section 1 09-30-2015 11:13 AM
