building a decent 3.8L
I'm always a big fan of the using the 4.2L crank as the building block of a V6 build.
4.2L with a mild cam, good heads/intake and blower go a long way.
If you are going this far, a 4.2L bottom end with the SuperCoupe M90 top end makes a killer combo.
3.8L split port heads are the same as the 4.2L heads. The only real change you can make use of is the 4.2L crank. The other difference is the upper intake, but it's huge and won't flow as well as the stock/ported 3.8L.
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
