building a decent 3.8L
Old 07-11-2014, 02:14 PM
TheGageinator
TheGageinator's Avatar
Update . The head shop just called and said that the valves aren't seating properly in either head. $80 a piece to rebuild.
TheGageinator is offline
Old 07-12-2014, 07:01 AM
BabyGT
BabyGT's Avatar
That's not bad. A 4.2 stroker will get you faster than a 3.8 but there's a reason there is a v8 in the GT.
BabyGT is offline
Old 07-12-2014, 10:20 AM
LilRoush
LilRoush's Avatar
I'm always a big fan of the using the 4.2L crank as the building block of a V6 build.
4.2L with a mild cam, good heads/intake and blower go a long way.
If you are going this far, a 4.2L bottom end with the SuperCoupe M90 top end makes a killer combo.
LilRoush is offline
Old 07-12-2014, 11:49 AM
TheGageinator
What about the 4.2 heads and crank? Or one or the other with my 3.8 block. I'm going to re use my 3.8 block for sure
Old 07-12-2014, 08:35 PM
TheGageinator
im going to get my 3.8 heads ported while they are at the machine shop i think. trying to find a 4,2 crank right now
Old 07-13-2014, 08:46 AM
LilRoush
LilRoush's Avatar
3.8L split port heads are the same as the 4.2L heads. The only real change you can make use of is the 4.2L crank. The other difference is the upper intake, but it's huge and won't flow as well as the stock/ported 3.8L.
LilRoush is offline
svfetter
10-05-2015 11:39 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
Demodulates
09-18-2015 11:14 AM
2015Ecoboost
09-17-2015 01:48 PM
degner122
09-16-2015 07:09 AM
Quick Reply: building a decent 3.8L
