need some help please........?
Old 10-19-2014, 01:14 PM
Mike_Stang
Mike_Stang's Avatar
Default need some help please........?
I have a 2002 mustang with a 3.8! It was automatic but i took the trans and rear end out of my old 99 and made the 02 stick shift. Both cars have the v6 but when i changed everything over from the 99 to the 02 and started it, it has a mad vibration coming from either the clutch or flywheel....i was told it was the flywheel and it is not properly balanced! Any help on how to set my flywheel on properly so theres no vibration? Im open to any suggestions!
Mike_Stang is offline
Old 10-20-2014, 07:07 AM
BabyGT
BabyGT's Avatar
Did you take the flywheel from the manual car?
BabyGT is offline
Old 10-20-2014, 08:09 AM
PNYXPRESS
PNYXPRESS's Avatar
Its because the 99 was externally balanced and the 02 is internally balanced. You will need an apr00-04 neutral balanced flywheel.
PNYXPRESS is offline
Old 10-20-2014, 10:18 AM
BabyGT
BabyGT's Avatar
I forgot about 99 being the awkward in between year.
BabyGT is offline
Old 10-20-2014, 10:21 AM
NYstang
MF Staff Snitch
NYstang's Avatar
what he said ^^^
NYstang is offline
Old 10-20-2014, 10:22 AM
PNYXPRESS
PNYXPRESS's Avatar
At least all 99's were externally balanced. The 00's were a mix of internally and externally balanced depending on when the engine was assembled.
Old 11-08-2014, 10:06 AM
Mike_Stang02
Mike_Stang02's Avatar
Default thanks :-)
I found that out and because ford stop selling these flywheel im lost on where to get one! Any ideas?
i really appreciate the help
Mike_Stang02 is offline
88 sleeper
09-09-2010 10:45 PM
RodeoFlyer
01-23-2007 02:59 AM
stilllearnin
02-06-2006 03:06 AM
blue5.0stangGT
03-19-2005 10:14 PM
Quick Reply: need some help please........?
