NOISE
#21
Have you tried isolating the noise with a mechanic's stethoscope?
Are there a smog pump and air injectors? You may have a leak somewhere. Since this system is connected right at the exhaust ports, a small crack in an injector tube (or loose nut) can sound like a tick (also look for soot on and around the tubes).
#22
no idon,t have a smog pump good try i scoped all the pulleys. the loudest one was water pump replace it. noise still comes from pump maybe it comes from timeing chain cover behind the pump i talked to mickanic??? thats not a chain noise he says i need help
#25
noise
i did check the power st. pump it,s ok tight not noisey. i called a ford dealer yesterday, he said to pull out the camshaft-position-sensor and inspect the gears . some time it make s ticks+taps nioses. i can only hope !!!!! anyboby know how to change one? need help
#27
Not just the gears on it, and he's talking about the synchro shaft, the sensor itself is just a magnetic pickup but take two bolts out of sensor, pop that bad boy off, if there is ANY oil or debris under it on the part still left on the motor then the shaft seals are gone/going out on the synchro shaft. When mine was starting to go out it would only squeek when cold and intermittently at that.
#29
Do like I said, pop the sensor off the top of it, if there is any oil or flecks of stuff under the sensor in the top of the shaft then a seal has gone out.
(side note, $100 is a good price for a dealer to look at anything motor related)
