Headlight Cover Foggy / Dirty
Old 12-17-2014, 11:38 PM
Daehawk
Daehawk's Avatar
Originally Posted by TfcCDR
Take the bulbs out and run a hair dryer on LOW into one of the holes for about 20 minutes. It might be easier if you take a chunk of hose to aim the warm air into the housing.
IS there some product to seal them up with so it doesn't happen again?..I was thinking the clear silicone in my caulk gun.
Daehawk is offline
Old 12-18-2014, 07:18 AM
BabyGT
BabyGT's Avatar
That's what id try, or possibly parts stores have some clear window sealant usually on the same isle as the rtv.
BabyGT is offline
Old 12-18-2014, 09:55 AM
TfcCDR
TfcCDR's Avatar
Not only no, but HELL no!
The absolute LAST thing you want to do is seal the headlight assembly!!!
When you turn on your headlights, the air in the housing heats up and expands. When you turn them off and it cools, it contracts. If not permitted to vent, your housing can be ruined.
The problem is that somewhere along the way, you let a lot (relatively speaking) of water get in there, and it takes forever for it to vent out. There may be an actual hole to let water drain, if so, it may be blocked. After all, this isn't a problem for more people, so there is something about your car that isn't the same as most others, and they're not sealed with silicone. Figure out the difference and you can fix it.
The reason for taking all of the bulbs out and blowing warm air through is to get the vapor out, replacing it with dry air.
TfcCDR is offline
Old 12-18-2014, 10:39 AM
PNYXPRESS
PNYXPRESS's Avatar
Actually yes you do want to seal up the headlights. Not in the sense of air tight, there are vent tubes on the back.
PNYXPRESS is offline
Old 12-18-2014, 12:55 PM
TfcCDR
TfcCDR's Avatar
If there are vent tubes, the headlights aren't sealed.
But, again, since the vast majority of Mustangs don't have a wet-light problem, something is wrong with the ones which do, and that needs to be corrected, not squirting RTV all over everything.
TfcCDR is offline
Old 12-18-2014, 01:30 PM
PNYXPRESS
PNYXPRESS's Avatar
Almost all aftermarket headlights suffer from condensation in them.
It's a known problem and sealing the housing is the fix.
Old 12-18-2014, 04:17 PM
Daehawk
Daehawk's Avatar
I will also tell anyone who is doing this to NOT touch the headlight bulbs. The oil from your finger will stick to the glass and cause a hot spot when they are on and burn out the bulb.
Daehawk is offline
Old 12-18-2014, 07:11 PM
TfcCDR
TfcCDR's Avatar
I dunno about either statement. I see a lot of aftermarket headlights, and very few have water in them.
I also see the occasional housing with a deformed mirror, and they seem to mostly have been sealed up with RTV.
TfcCDR is offline
Old 12-19-2014, 11:01 PM
Tele-Caster
Tele-Caster's Avatar
My 99 V6 was a rough, trailworn looking thing when i bought it, having severly hazed headlight assemblies among a long list of cosmetic defeciencies.
I cured the haze on mine by rubbing it out with a product called a "Magic Eraser" that I bought from the household goods department of Walmart -the department where you find the dishwasher soap and floor polish...
It took a lot of time, but the results came out great, with the haze totally removed.
Since that worked so well, I applied the things to my then nasty looking OEM alloy wheels. They worked like magic on the wheels, too, restoring them to new-looking cleanliness and luster.
And since that worked so well, I spiffed up my intake manifold and various other underhood parts...
Those Magic Eraser things have a lot of utility for making an old car look presentable again.
Tele-Caster is offline
Old 12-20-2014, 11:05 AM
TfcCDR
TfcCDR's Avatar
The only problem with de-hazing products is that the polycarbonate housing has a very thin hardened layer (scratch protection). Once you have taken off the layer (while taking off the haze) it will get hazy faster. However, this may mean 5 years instead of 10, so it's nothing to really worry about.
Any microabrasive will do the job. One popular method of polishing acrylic is to rub with toothpaste.
TfcCDR is offline
Quick Reply: Headlight Cover Foggy / Dirty
