P0174 suggestions appreciated
I have a 98 V6 dual exhaust with 278,000 miles on her (Built Ford tough, this baby is not found on road dead!). I need to smog my car and I have code p0174.
Some things I have tried: disconnecting battery, code keeps coming up.
Cleaning the MAF. Putting fuel injector cleaner in the tank. Checking for leaks with the naked eye.
I have had my fuel filter changed last year so I doubt it is that..
P0174 means the car is running lean on Bank 2, something that I find curious as bank 1 seems fine.
Any suggestions on what to try next are welcome.
I am leaning with PNYXPRESS as I pulled all the spark plugs on bank number 2 and tested to make sure they all sparked and were gapped correctly.
An o2 sensor would make sense now that I did much research on how they work and even watched a video of someone testing a faulty one and the voltage it was giving out would trigger a lean condition all the time.
I have checked for vacuum leaks, lose hoses, and even did a poor mans way of smoke testing the car to no avail.
With as many miles as the car has it would make sense that an o2 sensor could be bad.
treesloth
09-28-2015 07:03 AM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
