Engine jammed up, when cranking it over.
Old 03-25-2015, 11:42 AM
jwog666
jwog666's Avatar
never seen a bent crank, broke in half maybe, rods are always the weak link in a hydolock failure.
jwog666 is offline
Old 03-25-2015, 03:27 PM
irish1968
irish1968's Avatar
Weather is ****, so I have to wait. Car didn't always have this problem when starting, so I didn't worry to much, it was only a few times it happened, since I changed it. As for a fluid leak in the cylinder all summer, I doubt that. Car has sat for a week and started, and if there was an antifreeze leak, I would get a sweet smell from the exhaust, and a possible overheating issue. If it is a hydro lockup, I would assume it would be more from an open injector filling it. Until I check, hopefully tomorrow, we won't know. Until then, I will dream of a coyote in it, sit in it, and make my own engine noises! Thanks for the replies, send tissues, funeral pending!
irish1968 is offline
Old 03-25-2015, 07:43 PM
BabyGT
BabyGT's Avatar
You won't get hydro lock from fuel, it compresses, water/coolant does not.
BabyGT is offline
Old 03-25-2015, 10:13 PM
jwog666
jwog666's Avatar
liquid does not compress, no matter what kind of liquid. i have personally replaced 5.4l and 6.8l V8's with stuck injectors and bent rods due to fuel filled cylinders
jwog666 is offline
Old 03-26-2015, 08:09 PM
irish1968
irish1968's Avatar
Either way, haven't been able to check yet. Canadian weather sucks, been wet or too cold, and I have no shop at the moment, so it will sit for now. Will just have to locate a better engine, and a low cost shop that can do another transplant, or scrap the cursed POS. Looks great, as a lawn ornament! As for compressing gasoline, I agree, it is a liquid, not a gas, and can't be compressed!
Old 04-26-2015, 09:22 PM
irish1968
irish1968's Avatar
Just to let you know, I managed to remove spark plugs, and found gas in the #6 cylinder, which caused it to hydro-lock. Fortunately, because the engine was never running when it locked, only cranked over, nothing was damaged. The engine runs, and have been driving it a few times, and no problems. Still has the problem, with starting up on the first try, but that's another issue I will solve later. Will change out injectors, and a few other components later to resolve that issue. Thanks for your help, sorry for the delay in the update.
Old 04-26-2015, 10:50 PM
jwog666
jwog666's Avatar
u need to replace at least the #6 injector asap, as it is leaking and caused your fuel hydrolock, i have seen people wait too long, and the injector sticks wide open and then they bend rods
jwog666 is offline
Nick Oliver
10-17-2018 04:22 AM
StalkerGT
09-25-2015 02:41 PM
TfcCDR
09-14-2015 12:08 PM
MusicCity615
09-12-2015 07:05 AM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: Engine jammed up, when cranking it over.
