Trans fluid in coolant
Im looking for info on draining block of all fluid. Thanks to bad radiator i have strawberry looking shake in motor. If anyone has any ideas it would be greatly appreciated. Have new radiator but dont want to install it till engine clean. Its a 99 3.8 v6
you will haev to run a chemical flush in the cooling system several times and keep flushing till its clean, ur best bet due to the large ammount of flushing required is to have a reputable shop do this for you, at the same time you replace the radiator
Matt's 95 Stang
10-05-2015 07:16 AM
09-25-2015 06:42 PM
