Left front turn signal
Old 06-12-2015, 01:31 PM
mlollis
mlollis's Avatar
Default Left front turn signal
My left front turn signal will not work, nor will the left turn arrow on the instrument cluster flash. Every thing on the right side works.
Replaced flasher , not the trouble.
the bulb nor socket is the problem- swapped r to l and l to r
the right rear works ok.
Is there a relay or power module between the flasher that might come in to play?
Its a 1999 v6 convertible .
mlollis is offline
Old 06-12-2015, 02:52 PM
KrazyKen
KrazyKen's Avatar
Don't think there is anything between the flasher and the bulb except wiring. Check your wiring, may have a short, bad ground or loose wire.
KrazyKen is offline
bjdutch2005
03-24-2017 03:38 AM
Pyrate Dave
09-10-2015 07:30 PM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: Left front turn signal
