2001 convertible problems
Old 06-25-2015, 03:18 PM
boredcrazy
boredcrazy's Avatar
Default 2001 convertible problems
hey 2001 convertible i bought from a friend. top works but when i unlatch it i have to push it up a little bit so the motor pulls it down. and often i have to cycle the switch a lot to make the motor work. i have checked the fluid with the top up and bled the system..i dont know why it wont work. if i push it a bunch of times it will finally work. i hear it running but its loud and idk what to think. help please also i checked the emergency brake switch its working not corroded
boredcrazy is offline
Old 06-25-2015, 04:21 PM
BabyGT
BabyGT's Avatar
It's not the most quite thing in the world. When it's not working can you hear it running? If not then the switch might be corroded internally or have had something spilt on it. I had to clean soda out of the switch on my gt when I bought it for it to work.
BabyGT is offline
Old 06-26-2015, 02:19 PM
boredcrazy
boredcrazy's Avatar
seems clean its sealed so i can't pry it open i dont think? the plug is clean is it possible to open the switch up without breaking it?
Old 06-26-2015, 06:12 PM
BabyGT
BabyGT's Avatar
Before you tear it up let's get an answer to the question, when the top won't move does the pump make any noise?
BabyGT is offline
Old 06-27-2015, 05:54 AM
boredcrazy
boredcrazy's Avatar
no when it doesnt work it acts like the motor isnt getting power. ive checked and im getting power to the switch havent checked but assuming the motor isnt getting power when the switch isnt working also
Old 06-27-2015, 07:03 AM
BabyGT
BabyGT's Avatar
Okay, could have something gummed up in the switch, you will need to pull the switch out of the console. First you can try getting some electrical contact cleaner and saturating the switch, if it's soda or something of that nature it will clean it out. If that doesn't work the switch clips together, carefully pull it apart and make note of how any internal metal pieces are situated, clean everything with sand paper and reassemble.
Or if you can hit some junkyards find another switch. They aren't that uncommon to see in yards and reasonably cheap
BabyGT is offline
ohfarrell
10-18-2015 11:27 PM
MusicCity615
09-27-2015 12:53 AM
CarGuyZM10
08-31-2015 07:08 PM
kdryan
08-21-2015 04:01 PM
Stilz
08-19-2015 06:17 AM
Quick Reply: 2001 convertible problems
