egr pipe broken help
Old 01-16-2016, 10:00 AM
Rory Fraser
Rory Fraser's Avatar
Default egr pipe broken help
hey so my check engine light came on and i found the culprit the egr pipe/hose broke off at the conncector where the dpfe downstream hose connects to what should i do should i get a new pipe ( heard they are a PAIN to replace ) jb weld it can it handle the heat or get it welded thanks guys
Rory Fraser is offline
Old 01-18-2016, 05:41 PM
KrazyKen
KrazyKen's Avatar
Easiest way I have heard to fix this would be to get a used one off another Mustang. Don't think JB Weld will be able to handle the heat, but I would think welding would work as long as there are no leaks. What made it break in the first place? Did it rot out or something?
KrazyKen is offline
Old 01-18-2016, 06:29 PM
Rory Fraser
yea i was just driving code came on took my scanner checked it looked over on bank 2 removed my air box and their it was hanging on by a thread completely off i have checkd parts stores no luck so im going to phone ford tomorrow if they dont have it or if its really expensive ill weld it at school i know most of these are a bitch to remove because of how easy they rust or would exhaust epoxy work their is one i found good up to 2000 degrees
Old 01-19-2016, 08:49 AM
PNYXPRESS
PNYXPRESS's Avatar
Depending on where it broke will determine if you can fix it or not. The ends are a swivel fitting so you can tighen it,m without rotating the entire tube.
PNYXPRESS is offline
Old 01-19-2016, 02:03 PM
KrazyKen
KrazyKen's Avatar
Could always try an EGR delete. You will need to turn this off in a tune and this will affect emissions testing and mpg. Personally I don't advocate this, but it is an option.
KrazyKen is offline
Odessaep
01-19-2016 10:20 AM
ggfits
01-16-2016 05:51 PM
Spub
01-12-2016 01:56 PM
tomcamaro97
01-06-2016 10:04 AM
Quick Reply: egr pipe broken help
