Center Console Swap
02-04-2016, 05:06 PM
Center Console Swap
I have a 2000 with the dark charcoal interior. The cup holders in the center console are almost unusable because the shifter hits whatever is in the front one when I shift to 2nd or 4th. Is it worth swapping the redesigned center console with the cup holders moved further back from say a 2003 or 2004 model or does the shifter still get in the way?
02-05-2016, 08:23 AM
You can use a 01-04 console actually. I know the rear cup holder is a lot more functional and I believe the front one is too. However I think drink cups will still get in the way of you shifting, but the shifter wont hit them in the front.
02-05-2016, 11:09 AM
Thanks! I've seen some decent ones at junkyards for 20 bucks so I may spring on that. Did the interior color change in 01-04?
02-05-2016, 12:09 PM
I dont think so. The only problem you may run into is the wire length for your top switch reaching the new location.
02-05-2016, 09:09 PM
Sweet. I'm not too worried about wiring, I'll figure something out. Appreciate the advice
02-06-2016, 05:23 PM
MF Staff Snitch
depends on the year- parchment is the same, but they switched from black to midnight
02-11-2016, 01:10 PM
You may need the radio surround to for traction control/rear defrost as they are different but I agree the cup holders in my 99 GT sucked *****
02-12-2016, 08:23 AM
That shouldn't be an issue because I don't have traction control and my defrost is by the headlight ****
vincep99
02-26-2016 11:49 AM
02-17-2016 06:16 PM
miked31
02-03-2016 06:00 PM
blackliststang
02-02-2016 09:43 AM
Agentorange00
02-01-2016 06:35 PM
