How to pull an engine
I've looked and couldn't really find anything and considering I'm going to be pulling my engine this weekend, I should probably know what to do to pull my engine, what all do I need to disconnect besides the battery and motor mounts, or if there's already a thread that I missed explaining how to do so point me in that direction, any and all help is appreciated
I'd recommend that you start with a good manual, best $15.00 bucks you'll spend! Make sure you have all the tools you need, jack stands and engine hoist. Take your time and be safe, should be able to remove it in less than 8 hrs the first time. btw, auto or manual transmission?
Remove:
driveshaft
trans crossmember
radiator
airbox
shifter
hood (not needed, but will make like alot easier)
Disconnect:
clutch cable
speedo wire
reverse wire
throttle/cruise cables
fuel line
power steering lines
a/c compressor
motor mounts
any wiring harness going to chassis
exhaust
Also decide if you wanna pull engine with or without trans
driveshaft
trans crossmember
radiator
airbox
shifter
Disconnect:
clutch cable
speedo wire
reverse wire
fuel line
a/c compressor
motor mounts
exhaust
Remove:
driveshaft
trans crossmember
radiator
airbox
shifter
Disconnect:
clutch cable
speedo wire
reverse wire
fuel line
a/c compressor
motor mounts
exhaust
driveshaft
trans crossmember
radiator
airbox
shifter
Disconnect:
clutch cable
speedo wire
reverse wire
fuel line
a/c compressor
motor mounts
exhaust
Jishikatsu
02-20-2016 09:45 PM
