3.8 liter 2000 Mustang engine trouble
Try this and see if it helps you... could just be a relay
http://www.justanswer.com/ford/2xnyk...1413-know.html
Thx for the reply I have another question
No, you should be getting 12V to relay pin 1, if not, then poor connection somewhere from the engine bay fusebox, wiring, plugs?.. runs through a 30 amp fuse that is always hot...I would also check pin 4 ground. If you have a bad ground it will cause bad readings across the board.
Sorry, I don't know what the voltages should be at the TPS.. I have seen other's post that you should have less than 1 volt running at idle. From there it should adjust as the throttle is depressed
Hopefully somebody who knows tps better will chime in soon.
majcric
01-15-2016 02:15 PM
