Alignment question, pulls to the right
Here's a fun fact, most OEM's adjust caster slightly different between the driver and passenger side for just the reason that Jwogg666 described. It creates a slight pull to either side depending on which side has the least amount of negative caster. In most cases OEM's will set the caster a little more negative on the drivers side. Can anyone guess why?
Time's up, most roadways in the US have a slight peak towards their center (Crown) so that water runs off into the ditches and gutters. A slightly higher negative caster on the Drivers side helps to offset that so that the car tracks forward better.
Don't believe here, here's one point of reference. Many others are out there. Last section titled Road Crown and Custom Alignment. 2006 Ford Escape from the factory is set with more negative caster on the drivers side.
http://www.agcoauto.com/content/news/p2_articleid/176
I drove it today (it is my daughter's car) and the pull (on the same roads) fells less than before, maybe. I do test it on what appears to be level road with minimal crown, if any, and drive straddling the stripe sometimes. It's not perfect but tolerable, some people might not even notice it unless they were asked to notice it. I will keep an eye on tire wear and try not to sacrifice a set of tires. If it gets worse, I'll take it to somebody that specializes in Mustangs who can fix it. I've been asking around. I could take it to a dealership, that I didn't buy it from, but would rather find somebody (that is not just a glorified tire and battery store) who can figure it out and make it right. Maybe I'm expecting too much but maybe not.
