no dash or marker lights unless i hold switch just right
Ok, using test light on wires in connector
With switch unplugged from connector: Black w/ orange stripe-hot, tan w/ white stripe-no power, blue w/ red stripe-no power, solid brown-no power, red w/ yellow stripe- no power, green w/ yellow stripe-hot, solid grey- hot
With original switch:
With switch connected, turned off: Same as above
Switch set to running lights: Same as above
Switch set to headlights: Same as above except red w/yellow stripe is now hot
Switch held so all lights come on: All wires are hot
With new switch:
All is the same except for when switch is held to get running lights on, then no power on red w/yellow stripe
With new switch:
Whoops, somehow I skipped over that bit of info. Sorry for jumping to conclusions.
After slowing down and reading your posts more carefully, I see that you're not finding power at the tan/white wire. I believe that one's supposed to be hot. Check fuse #5 in the panel under the dash.
Well, turns out it was the fuse, when I looked under there before and checked all of them I didn't even question the open spaces, I just assumed those were for fuses not used in this car, but when I took a closer look at fuse 5 I realized it has contacts in it so I put a fuse in and it seems to work fine
So the whole problem is I'm dumb lol
Thanks for the help folks
tracejones@comcast.net
08-11-2016 09:52 AM
Stangboi4444
07-21-2016 07:04 PM
