no dash or marker lights unless i hold switch just right
Just got a 97 mustang with the v6 and I noticed that if I pulled the switch I got headlights but not dash or markers unless I pushed the switch just a little bit back in, so I bought a new switch and now it's the same thing except when I push it back in the headlights go off so I have either headlights or markers/dash but not both, what could be the problem?
Is the new switch bad, or is there something else going on?
That plastic connector can be replaced, but it's the wires and actual connections that I was worried about. That red/yellow wire is your dimmer switch feed, so if there's evidence of it getting hot, inspect that wire and its terminal (it can be popped right out of the plastic connector). Then make sure that attaching the connector to the switch doesn't push that or any of the other terminals out.
After checking wires and connections, test switch operation, and if there's still a problem, then it might actually be the switch after all.
A couple questions:
When you say "new" do you really mean that the switch is brand new, or was it just a used replacement, like from a junkyard?
Did you have to swap the plunger shaft from the old switch to the new one?
A couple questions:
I'm going to buy a new connector pigtail tomorrow I think just to be sure that that is all good there, the terminal on that wire is a little burnt looking.
the switch is a new Echlin switch bought from napa, I'm not inclined to trust that its good even though its new just because I have lots of issues with napa electrical in the past.
I did have to swap the plunger from the old to the new one, why?
Just a hunch. Maybe it didn't seat properly or something.
While you have it out, it couldn't hurt to verify continuity between terminals in different switch positions. When I replaced my headlamp switch, one of the spades was physically loose and was causing an intermittent connection.
