1999 V6 Will Not Start
Old 10-17-2016, 02:48 PM
Thumb
Thumb's Avatar
Default 1999 V6 Will Not Start
Hi everyone, I've got a '99 Mustang with a V6 and this morning it will not start. Plenty of battery juice, it just turns over without a hint of starting. Don't know if it's fuel related or ignition. It did this about 2 weeks ago but then I came back about 5 minutes later and it started right up like there was nothing ever wrong with it.
Any suggestions on what to look for, test, anything other than taking it to a shop?
I need to get this car running since it's my wife's car and if I can't get it running, she'll want to take my 2001 GT that I keep garaged all the time with only 6K miles on it! HELP!!!!
Thumb is offline
Old 10-17-2016, 08:55 PM
Thumb
Thumb's Avatar
Well, it finally started without doing anything. Maybe have it checked on a computer to see if there are any errors.
Thumb is offline
Old 10-18-2016, 06:00 PM
Daehawk
Daehawk's Avatar
Fuel or fire.
Fuel - fuel pump, filter, hoses, fuel rail pressure
Fire - spark, fuses, plugs, battery, alternator, wiring short or battery connection or ground
Daehawk is offline
Old 10-18-2016, 08:25 PM
Teamster63
Teamster63's Avatar
Default 04 mustang
Similar problem ,but my exhaust pipe had cracked about a foot from the headers drove like that for about a month then started feeling some resistance in what felt somewhat like air assist brakes on a big rig , a week ago it started missing when accelerating then yesterday on the way to work it finally gave out ,will crank but no start I sprayed starter fluid through the throttle plate .. nothing replaced the coil pack .. nothing ,any assistance is appreciated
Teamster63 is offline
Old 10-18-2016, 09:10 PM
Thumb
Thumb's Avatar
Originally Posted by Daehawk
Fuel or fire.
Fuel, the engine just started like there was no problem. I'm thinking it's a fuel pump maybe going.
Thumb is offline
Old 10-18-2016, 09:14 PM
Thumb
Thumb's Avatar
I did check the fuel rail valve and when I pushed the pin in no gas was present. I did the same thing afterwards when the engine started and there was fuel there so something is not getting fuel there when it happens.
BTW, how do you edit a post or can you? I don't see anywhere to do so.
Thumb is offline
Old 10-19-2016, 12:28 AM
Daehawk
Daehawk's Avatar
You can edit your post after so many post. Im thinking its 10 posts but not sure.
Daehawk is offline
Old 10-19-2016, 01:12 AM
Thumb
Thumb's Avatar
Ahh, OK.
Thumb is offline
Old 10-19-2016, 09:16 PM
mrwitty_1
mrwitty_1's Avatar
Might be worth replacing the fuel pump relay.
mrwitty_1 is offline
Old 10-19-2016, 10:37 PM
Thumb
Thumb's Avatar
Smile
It may be the problem and that would be an easy fix.....Do you know where it is?
Thumb is offline
