stangant's engine build thread
Old 08-12-2013, 06:58 PM
  #441
stangant
stangant's Avatar
stangant is offline
Old 08-19-2013, 07:01 PM
  #442
stangant
stangant's Avatar
well I got the tb in early so today went ahead and got it all on. I had to come up with a way to put the iacv on in the stock location without the tb having a port so i drilled out the bottom and taped in a barb and then filled in the port with plastic weld that hardens enough to tap as well. I still have to figure out a setup for the throttle cable and cruise control cable, thinking about getting a stock fitting and bending and welding a new setup.
As you can see i have a bit of a fitment issue with the coil pack here but I will fix it with some muscle.
stangant is offline
Old 08-30-2013, 01:34 AM
  #443
H1ck55ter
H1ck55ter's Avatar
looks great bud, cant wait to see ya so i can get to staring on my build.
H1ck55ter is offline
Old 08-30-2013, 02:57 PM
  #444
stangant
stangant's Avatar
Sitting waiting on stupid brass rings for the -an lines.
stangant is offline
Old 08-31-2013, 11:41 AM
  #445
Matt's 95 Stang
Resident Ginger
Matt's 95 Stang's Avatar
Damn I wish I could get away with building **** like this in Cali. Good looking project so far.
Matthew
Matt's 95 Stang is offline
Old 09-12-2013, 07:58 AM
  #446
stangant
stangant's Avatar
Well finally learned how to idle. Have an oil leak that needs fixed but I don't think it will be hard to fix.
stangant is offline
Old 10-03-2013, 10:31 PM
  #447
Double0SixShooter
Double0SixShooter's Avatar
Hey, what intake manifold is that??? The one on this page***
Double0SixShooter is offline
Old 10-03-2013, 11:49 PM
  #448
stangant
stangant's Avatar
01 windstar newer then the more popular version but this requires you to change both top and bottom manifolds. it goes from 6 to 12 runners (split port) and enables maximum flow for my turbo to breath.
stangant is offline
Old 01-17-2014, 08:12 AM
  #449
stangant
stangant's Avatar
Figuring this engine out has been tough. I am going to be going backwards for a bit and doing a different fuel system.
stangant is offline
Old 01-19-2014, 07:17 PM
  #450
samiamthemustangman
samiamthemustangman's Avatar
Great work man! I know the 01 Windstar fuel rail will not work with you set up. Will it work and is there no room for a fuel pressure switch?
samiamthemustangman is offline
Quick Reply: stangant's engine build thread
