Go Back   MustangForums.com > Ford Mustang Tech > 6 Cyl (V6) Applications > V6 General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-16-2009, 06:46 PM   #1
sonariz
Vehicle: 1997 ford mustang coupe
Default how much is too much?!?!?
i have a 1997 3.8L v6 mustang, 5 speed with the stock 2.93 gears. current mods are NGK iridum plugs with msd wires, in the next couple days will have bbk cold air intake, pacesetter exaust adapter with dual magnaflow exaust, accel super coil and bbk underdrive pulleys. My plans are to rebuild a t-5 world class tranny out of a 95' cobra and the rear end; then install them into my mustang. they'll be fully done with ford racing parts as well full front and rear suspension. i want to pull the motor and do a full rebuild also but with comp cams internals and cylinder heads from supersix motor sports, then pro charger supercharger with vibrant intercooler and chip it....how much power can i put into my engine before i have problems, ive been told roughly 400+hp due to the fact ther 3.8 has a 2 bolt main? what can i do, or what should i do...im hoping i am able to do what i have planned as ive been working on it for over a year.
sonariz is offline   Reply With Quote
Old 08-16-2009, 06:51 PM   #2
brent4
brent4's Avatar
Vehicle: 02 Sixxer
I believe 350-400 is the limit with stock internals. Is the pacesetter adapter the one that bolts on to ur existing y pipe so u can have dual exhaust?
brent4 is offline   Reply With Quote
Old 08-16-2009, 06:57 PM   #3
sonariz
im planning on replacing all internals with comp cams parts. and yes that would be the part. and also i am running full amsoil synthetics in my car with colt body kit and redoing the whole interior with full comp. stereo.
Old 08-16-2009, 07:00 PM   #4
ESG-642T
Send a message via AIM to ESG-642T Send a message via Yahoo to ESG-642T
comp cams internals?
__________________
Block .20 Bore 3.830, ARP Head Studs, Ford Girdle, Scat 4340 Forged 6.125" H-Beam with Ross Forged Dished Pistons 8:7:1 compression, KPP Cam Reground 224* .587" Intake / 222* .567" Exhaust 114 LCA, 110 IC, Self Ported Heads with Self Ported Upper intake ported lower intake with a matching ported throttle, Mac long tube headers, Flow master 40 series mufflers, 3.73 motive gears, Eaton posi trac, Sct livewire, Bilstien shocks and struts, Eibach pro kit springs. FS: POLISHED VORTECH V2 3.8L KIT
ESG-642T is online now   Reply With Quote
Old 08-16-2009, 07:03 PM   #5
sonariz
comp cams makes all the parts i need to do a full rebuild, you know... cams, pistons, lifters, rods etc... im doing everything
Old 08-16-2009, 07:21 PM   #6
brent4
brent4's Avatar
Vehicle: 02 Sixxer
For exhaust just get muffler of ur choice and let a exhaust shop fab u a true dual kit. Have you looked into getting your internal parts from supersixmotorsports?
Old 08-16-2009, 07:24 PM   #7
ESG-642T
Quote:
No, I never knew that....
Got a link?
__________________
Old 08-16-2009, 07:31 PM   #8
sonariz
ive looked into the exaust from a few shops and they both wanted double if not more the cost then what i paid for the adapter kit and magnaflow dual exaust kit.........nope i don't have a link but when your on their site u can search for 4 cyl & 6 cyl parts and they list everything with some different stages...... yes ive desided to purchase the upper and lower intake with heads from super sixe motor sports its callled their super pak im pritty sure, im looking at the stage 2+ kit maybe the 3....but im still worried about having a 2bolt main.
Old 08-16-2009, 07:45 PM   #9
ESG-642T
They don't have pistons/connecting rods/cranks/you know the important stuff to build a bottom end.
__________________
Old 08-16-2009, 08:03 PM   #10
sonariz
yes thats true my bad the internals are from supersixmotor sports...all forged pistons, ring, connecting rods, crankshaft but all the valve train and etc. for internal wise are comp cams
conversion, cylinder, dual, gt, heads, installing, mustang, oil, pacesetter, rebuild
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
