Go Back   MustangForums.com > Ford Mustang Tech > 6 Cyl (V6) Applications > V6 General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-21-2009, 02:01 PM   #1
shann123
Vehicle: 2004 Ford Mustang 3.9L V6
Default Engine whine
Something in my engine has recently started to whine, almost sounds like a power steering pump whine. It's an 04 3.9L. I had it up on ramps today trying to track it down and it sounds like it's coming from the oil pan. What would be under there causing that kind of whine?
Thanks!
shann123 is offline   Reply With Quote
Old 08-21-2009, 03:59 PM   #2
gif4445
gif4445's Avatar
Vehicle: 2003 GT
Well the steering pump on these mustangs do make a lot of noise, so that could be it
__________________
gif4445 is offline   Reply With Quote
Old 08-21-2009, 05:31 PM   #3
RyansQuick6
Reverse Gear Member
2001 Ford Mustang
RyansQuick6's Avatar
Vehicle: 02 V6 with some stuff
I think you answered your own question
__________________
Friggin OTards
Quote:
I learned an important lesson in the art of debate. Present your argument clearly, arm yourself with cutting wit and of course, bob and weave!
RyansQuick6 is offline   Reply With Quote
Old 08-21-2009, 07:13 PM   #4
Richbrad08
Richbrad08's Avatar
Vehicle: 2000, Ford, Mustang Convertable
I believe the only way to correct this problem is buying a "NEW PUMP" i bought a re manufacturer one but still made the same noise a tad bit quieter tho but still the whine is there. i believe the new one is 160 or 115 and 45 core charge for giving them yours.
__________________
2000 Ford Mustang Convert.
BBK CAi
BBK Headers about to be mac LTs
True Dual Exhaust
Ram HDK Clutch
Spec Billet Steel Flywheel
Screaming Demon Coil /Live Wires
Sct SF3 Tuner 93 performance tune
Upcoming UPR short throw Shift
Richbrad08 is offline   Reply With Quote
Old 08-21-2009, 11:12 PM   #5
shann123
But it's not coming from the steering pump though. It makes the same sound, but I had a stethoscope all over and it sounded loudest when I touched the oil pan with it. Would a main bearing make a noise similar to that?
Old 08-22-2009, 01:41 AM   #6
RyansQuick6
Reverse Gear Member
2001 Ford Mustang
It could just be transmitting through there as well though, the oil pan is basically a hollow open space and with a scope it will sound like a whine when what you're most likely hearing is the oil pump.
When you replaced the pump did you flush out ALL of the old fluid or just refill?
__________________
Friggin OTards
Old 08-22-2009, 10:30 AM   #7
shann123
I haven't replaced anything yet. I'm just trying to figure out what's going on before I start tearing things apart and spending money I don't have on parts I don't need.. lol. I've got a 1,400 mile trip I'm gonna be making next weekend and it'd really suck to break down on the road so far from home.
I'm going to be changing the oil tomorrow, so I'll poke around some more while it's up on the ramps again and hopefully I can find the source of the problem.
Thanks for the replies!
__________________
J-Mod (did myself) - Windstar Intake - UDP (temporarily back to stock) - aluminum driveshaft - 93 octane performance Tune from Justin @ VMPtuning - Grill Delete - Chin Spoiler - 8" shorty antenna - Many more plans, not enough $$
Old 08-23-2009, 06:12 PM   #8
shann123
Well, it does seem to be the power steering pump after all. I could hear it when I probed the back of the reservoir. It's strange because you can hear it really well inside the car, but if you open the hood to listen for it, you can't really hear anything. It also doesn't get any louder when you turn the wheel. I guess that's what threw me off. Hopefully it'll make it without any problems on the trip next weekend.
__________________
Old 08-24-2009, 01:22 AM   #9
RyansQuick6
Reverse Gear Member
2001 Ford Mustang
The reason you hear it in the car so well is bacuase it reverbs through the coulmn into the dash. Try to flush all the old stuff out before replacing it, see it that helps.
__________________
Friggin OTards
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
