Make sure you have proper air in your tires. Make sure everything is tuned well. Plugs, air filter, fuel filter, spray your throttle body & MAF sensor to clean those up, and run some Techron fuel cleaner through your tank. If you are car savy and have at least 50K miles on your car, right before you change your oil, run seafoam through it (following directions). Change your oil immediately after following those directions. If you dont know what your doing then just dont do it. I have done it on several vehicles with super results, but have heard about people doing goofy things and then messing their car up somehow?? You can also change to full synthetic in your motor, tansmission, and rear will improve gas mileage a bit and gain back some horsepower that you lose through the driveline.
__________________
2004 Mustang GT, 5 spd, Shadow Grey, 14K original miles.
