HIDs
i have 10000's, shaun its probably just your stock headlights. i had the same issue, i bought new smoked clear corners and they are bright as can be now. when i pulled the old headlghts out i saw that the cone inside of it that surrounds the bulb was dark black, on the new lights of course they are nice and shiny. so i think that was the culprit. 6k's are pure white and very bright, 8s and 10s are blueish. i like mine tho, the blue isnt that bad
If you can't get the kit from the guy Ryan is refering about go with vvme's 6k kit. I put mine about in and the run great. Turned out that the flickering was due to the positive battery cable that runs to the fuse box was coming undone. Replaced it and everything is perfect now.
The website is being remade AGAIN. Until then, I can take orders over the phone or through sni. Tell them to give me a call or text, 225-572-5729. Thanks for the recommendation, btw. We appreciate the help!
Thanks,
Andrew
Thanks,
Andrew
I can't remember what I paid for them, got em back in November, but it was a pretty good price. The headlights are dual, but the duals use a standard H1 halogen for the high beam. I drive in some very unlit areas, and I've never needed more light than the low beams put out. I only got them with the hi for inspection.
