Fuel reset switch - MustangForums.com
Old 03-19-2011, 04:35 PM   #1
my04stang
Default Fuel reset switch
Car won't start so I tried the fuel reset switch, and it doesn't move at all. should this have any give to it all? or should it not move if this is not the problem?
Thank you in advance for your help. Appreciate any info you can give.
my04stang is offline   Reply With Quote
Old 03-19-2011, 04:57 PM   #2
MustangSally94
MustangSally94's Avatar
Im assuming your talking about the Inertia switch? If so if it has been tripped you should be able to press it in to reset it... if it has any space between the top of the red button and the top of the part the button sits in then it isnt tripped... if it is flush on the top and wont press in my guess is somehow the switch has locked up somehow... if not then good luck finding your problem
MustangSally94 is offline   Reply With Quote
Old 03-31-2011, 08:34 AM   #3
my04stang
Thanks so much for the help. That appears to be the problem. Looking for switch now.
Old 03-31-2011, 10:23 AM   #4
my04stang
Default fuel inertia/safety switch
Okay, not so sure that was the problem, as far as the position of the red button on switch, should it be all the way to the top or closer to the bottom, but not touching the bottom? It is closer to the bottom, but not touching.
Old 10-20-2013, 10:12 PM   #5
Rob-1995-Mustang-GT
Hey, I'm having the same pob on my 95 Mustang GT-5 SPD I put in a fuel filter,fuel pump, Distributor assembly, cleaned all fuel injectors, Timing chain &gears and a new battery, Still no cold start but when I do get it to start she runs awesome but if I let it sit fo over 3 hrs no cold start!!. So I finily did a code EEC test using a paper clip & counting how many flashes the check engine does. I got one code 542 = Fuel pump Relay or CCRM. If you don't know how to do this go into Google & type 1995 Mustang GT KOEO KOER TEST. Good luck guys Thanks- Whitelion95GT
Rob-1995-Mustang-GT is offline   Reply With Quote
Old 10-22-2013, 08:07 AM   #6
BabyGT
BabyGT's Avatar
Wrong section bud this is the V6 section. Try over in the 5.0 section. You will prolly have better luck.
BabyGT is offline   Reply With Quote
95 gt dead fuel pump?? 9550 5.0L (1979-1995) Mustang 10 10-26-2015 05:01 PM
91 5.0 won't start Meystang 5.0L (1979-1995) Mustang 5 09-25-2015 04:05 PM
Fuel Pump & Injectors pimp2303 5.0L (1979-1995) Mustang 3 09-17-2015 08:45 PM
OBD: The Adventure Begins (PO402 and PO401), DPFE/EGR test procedures TfcCDR V6 (1994-2004) Mustangs 1 09-14-2015 12:08 PM
Will not fire up Wombatnation 5.0L (1979-1995) Mustang 12 09-13-2015 09:16 PM
2004, 2005, 95, bullit, button, ford, fuel, inertia, mustang, resest, reset, rest, start, switch, switchfuelreset
