Wanna read a build thread? Click me... (Fink's M112 Build)
Old 05-05-2011, 09:37 PM
Fink
Fink's Avatar
Sent a guy a message about a 04 throttle cable. TPS is ordered.
Found a 95 GT for parts, no engine or trans, $500. I mainly want it for the 8.8 and the black interior.
NGK or Autolite plugs? I had NGK TR55GP's and they only lasted 4 months, so Im a little hesitant about NGK.
Fink is offline
Old 05-06-2011, 01:37 AM
NeoTokyo
NeoTokyo's Avatar
If he falls through I am probably picking up an 01' GT parts car.
You can have first dibs on the cable.
NeoTokyo is offline
Old 05-06-2011, 01:52 AM
Fink
Fink's Avatar
Sounds good. Thanks for the offer.
Fink is offline
Old 05-06-2011, 04:37 AM
ESG-642T
Buyer Beware
ESG-642T's Avatar
Copper, plats suck... tr6
ESG-642T is offline
Old 05-06-2011, 03:10 PM
Fink
Fink's Avatar
After I the GP's failed I went to Ford and asked for coppers, they gave me platinums.
I havent seen a copper plug in at least 5 years.
Fink is offline
Old 05-06-2011, 05:42 PM
Fink
Fink's Avatar
TR6's will be here monday.
Do I seal the front snout and the rotors or just the snout on the M112?
INSTALL IS SCHEDULED FOR NEXT WEEK. Tuesday or later since I have a alignment on Monday.
Fink is offline
Old 05-08-2011, 08:40 PM
Fink
Fink's Avatar
L/U CA's ordered
Hose for PPRV delete ordered
04 throttle cable ordered
Just need to call Ford tomorrow and order some supercharger oil, grommet for fuel tank, and gear oil/friction modifier. Then drive an hour and a half(one way) to get the parts when they come in.
Also getting some POR 15 and a spray can of Electric Green.
**** me, looks like ill be spending a week in the garage.
Fink is offline
Old 05-09-2011, 07:46 PM
Fink
Fink's Avatar
So I got my alignment today and I was helping him do it. We adjusted the C/C plates as much as we can and we couldnt get the right camber.
Driver side is set at -1.2* and passenger is at -1.8*. Driver side is on borderline spec(-1.3* is where the green area starts). Passenger is obvious out of spec, even after fully adjusting the C/C plates.
So what he said to do was take the top and bottom plate off, lengthen the stock camber slots(only like 1/16-1/4") and then install the plates and adjust.
Passenger side:
Driver side:
Fink is offline
Old 05-11-2011, 06:53 PM
Fink
Fink's Avatar
axle removal started. Pics to come later.
ran into a problem... lower control arm bolts are rusted to the sleeve on the inside of the bushing. 10lb sledge + wd40 =/= bolt out. getting pretty frustrated.
Fink is offline
Old 05-12-2011, 05:57 PM
Fink
Fink's Avatar
Progress:
I HATE rusty/seized bolts.
Teaser:
I put the backing plates in an acid solution to remove the rust, so Im basically done while those soak and the LCA bolts soak in weasel ****. Tweaking my exhaust a bit since it hit the axle on certain bumps before.
Fink is offline
Quick Reply: Wanna read a build thread? Click me... (Fink's M112 Build)
