True Dual or H Pipe ?
Old 04-05-2012, 11:54 PM
austin184
austin184's Avatar
Default True Dual or H Pipe ?
Im geting new exhaust for my 6 this month and im trying to decide if i should get True dual welded behind the stock cats or dual h pipe welded from the stock cats ,And im geting flow master 40 series with 3inch tips .
Iv heard true dual helps on the back pressure witch helps on low rpm horse's and i also think true dual sounds better but whats your opinions h Pipe or true dual ?
austin184 is offline
Old 04-06-2012, 05:56 AM
mustangman02232
mustangman02232's Avatar
H pipe IMO with high flow cats, but go on you tube and listen to see what you like best
mustangman02232 is offline
Old 04-06-2012, 11:23 AM
BabyGT
BabyGT's Avatar
H-pipe, deleted two of four cats, and s-flow resonators
http://www.youtube.com/watch?v=yR1iG...e_gdata_player
BabyGT is offline
Old 04-06-2012, 11:25 AM
BabyGT
BabyGT's Avatar
Oh, I also didn't really notice a difference in low end torque really but it does feel much better up higher in the rpms
BabyGT is offline
Old 04-08-2012, 12:11 AM
d.girardi
d.girardi's Avatar
H pipe no cats and 40's and call it a day
d.girardi is offline
Old 04-08-2012, 10:05 AM
jthorn9
The Godfather
jthorn9's Avatar
Go with whatever is cheaper. Both will yield the same results on a stock car.
jthorn9 is offline
Old 04-11-2012, 04:22 PM
tbomb87
tbomb87's Avatar
I personally did the true duals with the H-Pipe and have never questioned my decision since I made it. So obviously I would recommend it. Good luck on your decision.
tbomb87 is offline
Old 04-11-2012, 05:56 PM
mustangman02232
power wise you are correct, sound will be different though
Old 04-15-2012, 07:10 PM
Adam_Ooh89
Adam_Ooh89's Avatar
I just recently had my 2006 mustang v6 exhaust system Y'ed off into duals and I love the new sound and feel. Combine that with a nice aftermarket exhaust and you'll be satisfied for a while.
Whatever you decide you put on make sure it'll pass smog too.
Adam_Ooh89 is offline
folivier
10-02-2015 05:34 AM
winner99
09-30-2015 07:04 PM
treesloth
09-28-2015 07:03 AM
09-24-2015 09:18 PM
JDWalton
09-24-2015 08:47 PM
Quick Reply: True Dual or H Pipe ?
