2006 Mustang AUtomatic Trans Problem
Old 01-29-2013, 04:16 PM
Dtdalke
Dtdalke's Avatar
Default 2006 Mustang AUtomatic Trans Problem
My 2006 V6 Mustang's Transmission just randomly disengages. The tranny works great 95% of the time but sometimes it acts like you just put it in neutral while driving down the road. The engine revs but the car doesn't go. It doesn't slip at all normally and the fluid is at the right level. If you back off and let it slow down some it will re-engage and will work just fine. It's usually happens when you are just cruising along with very light throttle application.
The car also has a check engine light and with P0108 code which is a MAP sensor code but the car doesn't have a MAP sensor. I would appreciate some info if anyone has seen either of these issues.
Dtdalke is offline
Old 01-29-2013, 10:32 PM
BabyGT
BabyGT's Avatar
Your posting in the 94-04 section
Try this section
It's for 05+ v6
http://m.mustangforums.com/forum/forumdisplay.php?f=48
BabyGT is offline
djbigskrilla
09-20-2022 01:04 AM
Mustangs of Illinois
08-22-2015 10:00 PM
PearlGenPu
08-12-2015 01:57 PM
daytooday
08-11-2015 09:22 AM
dfw692
08-07-2015 11:53 PM
Quick Reply: 2006 Mustang AUtomatic Trans Problem
