3.8 V6 in a 1995 Ford Mustang - MustangForums.com
Old 05-21-2013, 08:07 AM   #1
billiemself77
Question 3.8 V6 in a 1995 Ford Mustang
My question is I just put a 3.8 V6 in a 95 Ford Mustang and as soon as it cranks up it will die and I cant seem to figure out what the problem could be
billiemself77 is offline   Reply With Quote
Old 05-21-2013, 08:21 AM   #2
Stevo86
You didn't do something right. Check your work.
Stevo86 is offline   Reply With Quote
Old 05-25-2013, 11:35 PM   #3
go-part
Former Sponsor
Check and make sure all your sensors are plugged in correctly.
Also be sure you have proper fuel pressure at the rails.
go-part is offline   Reply With Quote
Old 05-26-2013, 12:03 AM   #4
jthorn9
The Godfather
jthorn9's Avatar
Try unplugging the fuel relay switch in the trunk then plugging it back in, this resets the fuel system.
If that doesn't work, then odds are you forgot to hook something up or hooked something up in the wrong order.
jthorn9 is offline   Reply With Quote
Old 05-26-2013, 09:58 AM   #5
Stevo86
That is the inertia switch and no it doesn't "reset" the fuel system. If it is jarred it will create an open circuit which shuts off power to the fuel pump. Pressing the red button resets the switch after it has been tripped but otherwise does nothing.
Old 05-27-2013, 09:48 PM   #6
billiemself77
Default How to do away with the anti-theft system
How can you remove a anti-theft system in a 1996 Ford Mustang 3.8 V6 automatic
Fuel Pump for 98 3.8L model. Not sure which type? mrappe V6 (1994-2004) Mustangs 0 09-26-2015 11:16 AM
ranger blower col2560 V6 (1994-2004) Mustangs 3 09-25-2015 09:59 PM
Fort Wayne, IN new member ShaneB26154 New Member Area 5 08-28-2015 05:47 PM
89 5.0 swap into 2002 3.8 Stilz Motor Swap Section 0 08-18-2015 10:40 AM
The World According to Motor Trend Sidewayz6.0 Off Topic 8 05-11-2004 12:56 AM
