So tomorrow ill be taking apart the whole upper intake manifold and cleaning out imrc's on my v6 but i just wanted to know if there was any fluids i should drain before doing so
If your just removing the upper intake then there are no fluids to worry about. If you are also removing the lower intake then you should drain the coolant. Good luck...
