Cooling Fan Problems
Old 06-29-2015, 04:36 PM
jstrothe
jstrothe's Avatar
Default Cooling Fan Problems
Alright,
so my fan will not kick on at all. I have replaced the CCRM (where the radiator fan relay is located), replaced the 30a fuse, the temper sending unit. All of this and the fan still does not kick on when its supposed to.
I have made sure the fan works when connected to a battery.
I also tried the manual switch route. I wired (10gauge wire) a positive wire from the fan to the battery with an inlet fuse(30a) then I wired the negative wire from the fan to the switch. grounded the switch and everything.
The problem is when I turn on the switch the fuse blows every time, even the 30a. A friend of mine suggested that the fan itself was drawing too much power and thus blowing the fuse.
What are my options here? How can I test to see if its just a fan problem or if there is some kind of electrical problem hidden away. Im willng to just go the manual route, but why does my fuse keep blowing? HELP PLEASE!!
jstrothe is offline
Old 06-29-2015, 09:48 PM
jwog666
jwog666's Avatar
you have a short somewhere, thus the blown fuse
jwog666 is offline
Old 07-03-2015, 06:26 PM
jstrothe
jstrothe's Avatar
where could i possibly have a short at?
i took the fan motor out and did the manual switch route and it turned on just fine, but when i put the fan shroud back onto the motor and then turned the fan back on the fuse blew.
could a short of another system be the problem?
jstrothe is offline
Old 07-03-2015, 07:54 PM
jwog666
jwog666's Avatar
did u draw test the fan? if not the fan or the wiring are drawing more than the fuse is rated for, try unplugging the fan and see if the fuse blows still, if not, then the fan is the cause, if it still blows then you have a short. where is it u ask? it could be anywhere from the fuse to the fan connector.
jwog666 is offline
Old 07-28-2015, 12:44 PM
Sawfish
Sawfish's Avatar
You probably have a wire that has worn, or burned through. Be sure that something had not fallen out of its harness into an exhaust manifold.
Sawfish is offline
Galactic
04-29-2019 02:56 PM
11-10-2015 11:39 AM
Pyrate Dave
09-10-2015 07:30 PM
09-03-2015 07:14 PM
Quick Reply: Cooling Fan Problems
