Instaling squential tail lights
Old 04-24-2006, 08:51 PM
JerryinTO
JerryinTO's Avatar
Default Instaling squential tail lights
Got my sequnetial tail lights today. when I had a look in the trunk of my 06 convertible and peeled back the rear trunk liner, there was no direct access to the light brackets. There's a metal part in front of them. How do you get access to the lights?
J.
JerryinTO is offline
Old 04-24-2006, 08:58 PM
Hupperware
Hupperware's Avatar
Default RE: Instaling squential tail lights
I just did my girl's vert. Took all of 15 minutes. You need to take out the plastic liner that surrounds the latch. Then remove the 3 7/16" nuts on each side holding each tail in place. 2 of the nuts on each side are behind the carpet. Flex it back, deep well socket it, and away you go.
Hupperware is offline
Old 04-24-2006, 09:10 PM
05kecarr
05kecarr's Avatar
Hey guys I was considering getting these tails too. When you brake and they light up, is it like 1,2,3 and it stops as all 3 lights light up? Or do they keep on blinking as you are still on the brake? I want them to just sequential once and then all light up and stay that way. Possible?
05kecarr is offline
Old 04-24-2006, 11:25 PM
Hupperware
Hupperware's Avatar
The ones I got from WebElectricProducts.com go on 1-2-3 very rapidly then stay on. When you are on the brake and signal, the signal side has no simutanious brakelight function.
Old 04-24-2006, 11:29 PM
gabeh1018
gabeh1018's Avatar
yea i just recently installed the web electronic sequential tail lights... i got the cheaper "do it yourself" kit.... it took a little bit of effort... but its works perfectly.... but its great.. all 3 lights light up from the inside to the outside.. same with the blinker and hazards..
gabeh1018 is offline
Old 04-24-2006, 11:55 PM
JerryinTO
JerryinTO's Avatar
I can't see how to access the lights. Part of the back of the car is in front of the lights. Do you have to remove something else besides the rear trunk liner??
J.
gabeh1018
gabeh1018's Avatar
there are 3 nuts that you must unscrew from inside the trunk.. then the whole light harness will pull out
Old 04-24-2006, 11:59 PM
Hupperware
Hupperware's Avatar
The entire plastic red/black piece of the taillight comes out.
Old 04-25-2006, 12:03 AM
gabeh1018
gabeh1018's Avatar
ORIGINAL: Hupperware
that is correct... dont worry.. you just pull and it comes out nice and easy.. then you can come remove the 4 light sockets..
Old 04-25-2006, 12:24 AM
JerryinTO
JerryinTO's Avatar
When I'm bending the liner back, this is what I see
[IMG]local://upfiles/13821/210445A9E4824B74979B439B1A339AFE.jpg[/IMG]
Quick Reply: Instaling squential tail lights
