take off rear axle...?
Old 09-29-2006, 05:50 PM
nonstopred
nonstopred's Avatar
Default take off rear axle...?
http://www.speedconcepts.net/product...roducts_id=728
650 seems cheap for this compared to an lsd w/ an install.
how do you think this would be to put in by yourself.
nonstopred is offline
Old 09-29-2006, 11:50 PM
scrming
scrming's Avatar
Default RE: take off rear axle...?
ORIGINAL: nonstopred
wow.. that seems like a great deal!
But since these are take-offs what where they coming from and what are they replacing them with??? These would have come off an automatic... hmmm...
scrming is offline
Old 09-30-2006, 12:12 AM
nonstopred
nonstopred's Avatar
maybe saleen takes them off, if they throw a supercharger in them b/c its too powerful. Not sure though. If I were to get one I'd have to find out the specifics. Just wondering what the ordeal is for an install
Old 09-30-2006, 02:07 AM
Pyrat
Pyrat's Avatar
I am (or maybe was) just about to buy one from Hillbank for $850+$50 s/h, with 3.55 gears, marked down from $1199+$50 s/h and from what I was told, Ford sells them for $1700, so I'd say is was a good deal ($650+$120 s/h).
The 3.55 is from a manual transmission GT and the 3.31 is from an Automatic GT. Now, the questions are:
1. Will the drive shaft on an automatic V6 bolt up to the rear end from a manual GT with the 3.55 gears?
2. Will the drive shaft on an automatic V6 bolt up to the rear end from an automatic GT with the 3.31 gears?
3. Will the drive shaft on a manual V6 bolt up to the rear end from a manual GT with the 3.55 gears?
4. Will the drive shaft on a manual V6 bolt up to the rear end from an automatic GT with the 3.31 gears?
Pyrat is offline
Old 09-30-2006, 05:35 AM
chrisc
chrisc's Avatar
lol, you want to put that on by yourself?
chrisc is offline
Old 09-30-2006, 05:49 AM
|UCF|chron
|UCF|chron's Avatar
ORIGINAL: Pyrat
if ur already upgrading ur rear end so much that ur replacing it wiht an 8.8, i would just go ahead and get the powerhouse driveshaft, bc ud obviously be etting it bc u need ur car to handle more power, so might as well get the new drivesahft so it doesnt break on the dyno or worse the street.
|UCF|chron is offline
Old 09-30-2006, 11:05 AM
Pyrat
Pyrat's Avatar
ORIGINAL: |UCF|chron
ORIGINAL: Pyrat
Eventually that will happen, but for now I need to determine if the existing drive shaft will work with the 8.8 rear end.
Pyrat is offline
Old 09-30-2006, 01:07 PM
tacatc
tacatc's Avatar
I am not sure which rear they are using but the CS6 has an 8.8 rearend so it must be possible. But I have no idea how you would go about swapping them out.
tacatc is offline
Old 09-30-2006, 03:05 PM
Pyrat
Pyrat's Avatar
According to Jason at Hillbank the rear ends on sale are 8.8 3.55 LSD units and they are the same rear end used on the CS6. The rear ends they have on sale are take offs from the cars Shelby built the GT-Hs from so they are standard GT units, but since they are 3.55s the base Mustang GTs and resulting Shelby GT-Hs must have be manual transmission cars I've ask about the drive shaft compatibility in a couple of other places and I ask the people at Powerhouse, so when I get an answer I'll post it here.
Pyrat is offline
Old 09-30-2006, 06:17 PM
|UCF|chron
|UCF|chron's Avatar
ok, bc i also want to kno, thanx
4cylinderplus2
10-09-2020 07:45 PM
baddog671
07-26-2016 01:20 PM
flash_xx
10-16-2015 07:23 AM
UrS4
09-30-2015 10:13 AM
lincolnshibuya
09-24-2015 10:46 PM
Quick Reply: take off rear axle...?
