How to spin both tires.
Old 11-03-2006, 12:04 AM
fazm
fazm's Avatar
Default RE: How to spin both tires.
ORIGINAL: Horrific_Ending
so bascially you have to buy a GT Rear axle buy a T-lock then the gears?
if you buy a gt rear, it comes with a tlok already.
if you want to keep your 7.5" rear, then you buy an lsd of some sort (tlok, auburn, truetrac) and put gears in at the same time if you want gears.
fazm is offline
Old 11-03-2006, 01:36 AM
rmays06
rmays06's Avatar
Its hard to believe that something so small and so cheap is this hard to comprehend and do. Gears suck...until you install them that is.
rmays06 is offline
Old 11-05-2006, 12:46 AM
Horrific_Ending
Horrific_Ending's Avatar
will THIS fit in our cars?
Horrific_Ending is offline
Old 11-05-2006, 12:55 AM
LL88
LL88's Avatar
What is the advantage to having power to both wheels?
LL88 is offline
Old 11-05-2006, 02:26 AM
Rnstanger
Rnstanger's Avatar
Yes, I've never heard of that brand though
Rnstanger is offline
Old 11-05-2006, 12:00 PM
mustangman02232
mustangman02232's Avatar
yes but these are better http://americanmuscle.com/v6gears.html - mustangboards is teh discount code
dont foget a motive bering kit http://americanmuscle.com/rearendrebuild1.html
detroit true trac
http://www.drivetrainspecialists.com...ruetrac-1.html
and if you dont have one, you need a tuner
http://www.vmptuning.com/store/index.php?
mustangman02232 is offline
Old 11-05-2006, 01:38 PM
Horrific_Ending
well thanx for the advice mustangman02232, but i dont want to run 4.10 gears. I want to run 3.73 just because of the high rpms on the freeway. and another thing i know i have to get the car retuned for the speedo to work right or whatever. But right now i am running a evo tune. Will this effect my performance tune or should i be alright?
Old 11-05-2006, 04:37 PM
ricekiller06
ricekiller06's Avatar
the advantage of having power to both wheels is that it doe handle better. and if you into racing ( drag and some street) that would mean a better wholeshot
ricekiller06 is offline
Old 11-05-2006, 04:41 PM
28HopUp
MF Administrator
28HopUp's Avatar
With your hand-held tuner, you can go into the optional parameters and change your gearing over to the new ratio (I'm not sure if EVERY ratio is in there or not but 3.73's are). No need to send anything back to Fred @ Evol - you can do this yourself.
28HopUp is offline
Old 11-05-2006, 11:27 PM
Denny Carlton
Denny Carlton's Avatar
Hey! All 6er's
I've pass the 500 mile marker for breaking in the new Strange 3.73 gears, no need to breakin the T-Lok.
This car now can pin your back to the seat, with the new gears & t-lok. These strange gears and t-lok are great. I had RealSpeed on Long Island install them, same people that did my dyno. I think they did a good job. Both wheels spin a little and the pull is much better than before. My bill was under $800.00 for the Strange Gears, T-Lok,g-kit, g-oil & Labor plus Tax[:'(]
Hey!
If your looking to burn two wheels, then you need to get some type of posi-rear and for a stronger pull, off the line then you need to get 3.73 gears or better. Depending on your driving needs for the vehicle, if your going to race and no highway driving, than get the 4.10 and if your going to do light street racing/Highway driving, than go with the 3.75 gears.
__________________________________________________ ___________________________
2006 V6 4.0L Stang
Black/Beauty
Mods:
Airaid CAI
Single Flowmaster American Thunder, Alxe-back
Custom X-Cal SCT II Tune from "ReelSpeed"
Royal Purple, Motor oil "Pep-Boys"
Strange 3.73 Gears w/Redline g/o "RS"
Ford Racing T-Lok "RS"
TLC/ABS
My next upgrade: Is the powerhouse driveshift for the 2006 v6 4.0L Mustang.
ps: One Step At A Time.
Check you all later,
Denny Carlton
[IMG]local://upfiles/47981/5F2EC3014F1E4C3B87C18CBA776E6B9D.jpg[/IMG]
Denny Carlton is offline
Quick Reply: How to spin both tires.
