underdrive pulley
RE: underdrive pulley
What pully? Crank or alternator? Alternator seems pretty easy, the crank might be a little more involved. People usually do one or the other. Both together did not dyno well. As for beign worth it...Every little bit adds up in the end. IMO I think the alternator pully is worth it because its a lot less expensive then the crank pully and yeilds similar gains.
I was using the alternator pulley but i took it off since iam on my third alternator. I will leave it off and see if the pulley is the culprit..last alternator lasted 2 months, one before thant 3 months.
ORIGINAL: 4.0 Stang
How hard is it to install a underdrive pulley and is it worth it.
Eric
ORIGINAL: Stolen 98
That sounds pretty in depth? For one BOLT-ON pulley. You never get the whole truth from 5.0 or muscle RAGS. Are the gains worth it???
I have an artical in the latest mustang 5.0 magazine that says its a 20% increase in power. Ill scan it so you can havea crap about it. BTW its a 86 inch belt.
ORIGINAL: scrming
For 4 to 6 RWHP... I never did find the proper belt... the one they recommended was to long... I tried one a bit shorter... it was to short and the belt tensioner start making noises... I finally just put the stock pulley back on.... LOL!
ORIGINAL: Stolen 98
http://www.mustang50magazine.com/tec.../photo_01.html Look here this is the artical that I was talking about. Ill still scan the entire artical.
