Muffler help please!! #*@!$#&
Old 01-12-2007, 11:19 PM
cookiemonster
cookiemonster's Avatar
Default RE: Muffler help please!! #*@!$#&
Thanks for the tips blackfoot ... however, for my Magnaflow, there aren't any threads on the back pipe connecting to the exhaust piping of the car .. should I just smear it all over the metal where the two parts meet?
cookiemonster is offline
Old 01-13-2007, 04:16 PM
blackfoot
blackfoot's Avatar
theres no clamp to keep that part tight to the rest of the system????
i think you got jipped because i thought it came witha clamp.. and im almost sure ive seen it...
you could go to your local autoparts store and buy a (the right size) U bolt clamp, or band clamp for exhaust systems
U-bolts tend to creat a ridge within the piping and if you wanted to remove it you would need a torche to heat the metal.. a band clamp does the job, but they are known for no sealing the exhaust system.. but if thats not an issue (which i dont think is) you can get your system apart no problem 80% of the time.
i recomend a band clamp
blackfoot is offline
Old 01-13-2007, 04:36 PM
cookiemonster
Yeah, the muffler came with a clamp ... and I'm clamping it verrrry tight, but it's still coming loose. I'm thinking about using some Permatex Hi-Temp Metal Repair Compound to seal the two parts together, along with the clamp.
Old 01-14-2007, 12:32 AM
blackfoot
blackfoot's Avatar
well you use the lock tight on the treads that clamp the clamp.. lol that sounds funny
Old 01-14-2007, 06:22 PM
cookiemonster
Thanks blackfoot - I'll give that a try!!
Old 01-14-2007, 11:41 PM
sonicblue05
sonicblue05's Avatar
your just not getting it tight enough man....if you were it wouldn come off lol crank it on therre and i mean CRANK!
sonicblue05 is offline
Old 01-15-2007, 12:40 AM
blackfoot
blackfoot's Avatar
threads are easy to strip.. git-r-tight .,but dont strip the threads ahaha
FivePointToTheOh
10-02-2015 04:09 PM
MustangV6P
09-28-2015 11:00 PM
DtRockstar1
Mustang Videos
09-27-2015 07:46 PM
09-10-2015 08:39 PM
Webster454
09-07-2015 04:59 AM
Quick Reply: Muffler help please!! #*@!$#&
